Old 02-13-2015, 10:48 PM   #1
theom
Drives: FR-S 2013
Better Door Stays?
Is there a way to adjust or change out the mechanism that holds the door open? Weakest door "hold open" spring I've ever encountered. Minor whine for an awesome car. I love my FRS and have light mods on it. but I wish the doors stayed open better.
theom is offline   Reply With Quote
The Following User Says Thank You to theom For This Useful Post:
mx5 2nr (02-18-2015)
Old 02-14-2015, 03:15 PM   #2
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
Finally someone asking about this, not a single time did I open the door and it hasn't come back wanting to close itself like someone has pushed the door deliberately towards my face -.-.
Yamajee is offline   Reply With Quote
The Following User Says Thank You to Yamajee For This Useful Post:
8R6 (02-14-2015)
Old 02-14-2015, 04:04 PM   #3
CyberAkuma
OOH KILL EM
CyberAkuma's Avatar
Drives: FG1 Civic,NA Miata, Whiteout FRS MT
Yeah, that is something that bugs me about this car lmao
Instagram: 8as6
CyberAkuma is offline   Reply With Quote
Old 02-14-2015, 04:56 PM   #4
lastexile1987
lastexile1987's Avatar
Drives: Lightning Red '13 Limited BRZ
The door gave my fiance a big bruise on her leg about half a year ago. She wasn't looking while trying to find something in the glove box and bam!! I also have a mini and damn those doors are heavy too. Of course they need a lot of reinforcement because it is a small car
lastexile1987 is offline   Reply With Quote
Old 02-14-2015, 05:50 PM   #5
Poodles
Drives: 2015 Series.Blue
Probaly the same door stays they use on their 4 door models. Add in a larger and heavier door and things happen.
Don't think there's going to be much you can do about it. Unless someone makes a better unit at least.
Old 02-18-2015, 05:32 PM   #6
mx5 2nr
Drives: FRS/NA1/'12 Mustang/'97 4Runner
I'm glad I'm not the only one that noticed that! I've got a pretty steep driveway & I've learnt to park the car with the nose to the street to avoid having the door close on me when I park on the driveway.
'90 Miata - weekends
'13 FRS - weekdays
'97 4-Runner - grunt work
'12 Mustang - wife's
mx5 2nr is offline   Reply With Quote
Old 02-18-2015, 06:27 PM   #7
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
The annoying part for me is that I will have my hands full, so I will try to swing it open and hop out before it comes back and closes. Most of the time it ends in my boot scuffing up the door.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 02-18-2015, 08:00 PM   #8
996garage
996garage's Avatar
Drives: 03' NSX & 13' BRZ 6spd Ltd white
Perhaps you can either file/dremmel the notches in the black door stay bar a bit deeper? Or maybe better to add material to the bar by layering some strong tape to build up the space in-between the bar notches so that it makes it more difficult to swing from one notch to the next? (the black bar is actually plastic)
On a related issue, I found the 1st notch opening point to be too narrow to get out, while the 2nd one was too wide to open in the parking lot at my work. This was maddening since you either had to be a contortionist to get out on the 1st notch, or rest your door on the car next to you using the 2nd notch. Therefore I used a dremmel/file to create a new notch in-between 1 & 2, and now it works perfect and I'm very happy with the results!
996garage is offline   Reply With Quote
Old 02-18-2015, 08:18 PM   #9
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I just always wrote it off as the car not wanting me to leave it...
but it is pretty darn annoying
The Following User Says Thank You to continuecrushing For This Useful Post:
funwheeldrive (09-26-2017)
Old 02-18-2015, 08:56 PM   #10
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Door check strap.
The only way you can impove it is by increason the thickness of the bar so it has more bite in the groves. You wouldn't want to gring the notches and further themselves as they will cause the door to pop during opening/closing. Take the door panel off, remove the 2 bolts from the body and the 2 from the door side and pull the check strap off into the the door and remove from the opening.
You would then have to reweld/grind or modifly your new bar and reassemble. Wrapping the part in tape would only work for a while as eventually the friction will wear the tape or push it into the pocket of the check strap possibly impeding function.
Old 09-26-2017, 03:11 PM   #11
ermax
ermax's Avatar
Reviving an old thread. This problem is driving me nuts. I am assuming Subaru repurposed a check strap from one of their 4 door cars when really they should have engineered a new check strap capable of handling the extra mass and wing of a long 2 door.
I think this weekend I will remove one of mine and see if there is anything I can do to improve it. This would be a great aftermarket part.
The Following 3 Users Say Thank You to ermax For This Useful Post:
Beachin86 (09-26-2017), funwheeldrive (09-26-2017), spike021 (09-26-2017)
Old 10-01-2017, 10:06 AM   #12
ermax
ermax's Avatar
Okay I found a small break in the rain to go take my door panel off. After taking off the door panel it is easiest to remove the speaker to get your hand in there to remove the stay check. I put photos with captions on Imgur here:
https://imgur.com/gallery/ik6Y2
In my captions I said I put 3 layers of tape on each side. I actually only did two but I can already tell that three would have been better. The door is much better but still wants to close on steep hills. Luckily in Florida we don’t have many of those.
Oh, while you are in the door panel, add some duct tape to the window switch box so it doesn’t rattle when you have the radio turned up.
The Following 2 Users Say Thank You to ermax For This Useful Post:
EndlessAzure (05-31-2021), WNDSRFR (11-22-2017)
Old 10-01-2017, 10:27 AM   #13
ermax
ermax's Avatar
Better Door Stays?
Damn, thinking about it now. I should have used aluminum tape and rather than tape the plastic part I could have taped the inside wall of the casing. I will probably redo this some day this week.
Old 11-21-2017, 04:10 PM   #14
sofrsnsokleen
GEARS!!???
sofrsnsokleen's Avatar
Drives: raven black 2013 scion fr-s
Location: the southeast side of san antonio, where the players play!
OMFG SOMEONE FINALLY MADE A POST ABOUT THIS!!!!
I thought for sure my car was just flawed and I was too lazy to take it in to the dealer.
It's really annoying and embarrassing to have to constantly kick your foot out to constantly catch the door from slamming shut.
And for me, it really only seems to happen on the drivers side.
sofrsnsokleen is offline   Reply With Quote
The Following User Says Thank You to sofrsnsokleen For This Useful Post:
theneptune86 (05-29-2021)
Airbag light stays on after removal/reinstallation Pablitomarrero Issues | Warranty | Recalls / TSB 13 04-04-2014 08:34 AM
exclamation light is on and stays on yellow SuperDave Issues | Warranty | Recalls / TSB 30 04-03-2014 11:48 AM
Courtesy Light Stays On After LED Upgrade milhouse Cosmetic Modification (Interior/Exterior/Lighting) 11 01-28-2014 03:45 PM
Can opening door too wide cause damages to hinge/door? Weeber Scion FR-S / Toyota 86 GT86 General Forum 3 11-25-2013 10:07 AM
What stays cleaner looking DBacon1052 Scion FR-S / Toyota 86 GT86 General Forum 16 01-20-2013 01:19 AM
