Old 08-03-2013, 08:04 AM   #1
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
Airbag light stays on after removal/reinstallation
I recently changed my steering wheel and to do so I had to remove my air bag. everything went smoothly and I reinstalled it after i was finished. real easy, straight foward. everything is great with the exception that my dash airbag light is on (guy sitting with a beachball on his lap).So im in my scion service dpt checking out an issue with my alarm and I asked them to please reset it. 77$ hell no. Any other way around this?
Pablitomarrero is offline   Reply With Quote
Old 08-03-2013, 09:27 AM   #2
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
This is completely unhelpful to you, but just out of curiosity, which steering wheel did you get?
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 08-03-2013, 09:32 AM   #3
Pablitomarrero
Lol, dct motor sports. I made a thread about it in interior mods. F...ing love it
Old 08-03-2013, 09:45 AM   #4
Anthony
Weight Nazi
Anthony's Avatar
Oh, and I doubt this would actually solve your problem, but did you at least try disconnecting the battery? I would assume you disconnected it for the installation anyway, but maybe try it again? I've come to learn that when it comes to electronics, everything runs on Windows and just needs to be restarted sometimes.
Old 08-03-2013, 09:48 AM   #5
Pablitomarrero
Im gonna try when i get home, just wanted to make sure it worked! 77 is too much for just connecting to a computer
Old 08-03-2013, 09:53 AM   #6
Mikem53
Drives: FR-S 6MT
Try to find someone with the techstream software and cable.. You can buy the cable for 25$ on amazon.. And download the software on here.. I have it and used it to change some options.. But don't know if there is the ability to reset the airbags.. You might do a search and check..
Mikem53 is offline   Reply With Quote
Old 08-03-2013, 09:58 AM   #7
Anthony
Weight Nazi
Anthony's Avatar
Hell, if the cable cost $77 I would still do it. Better to pay roughly the same price and have something to show for it than to not. But at $25, that's a no brainer. If it works.
Old 08-03-2013, 10:03 AM   #8
Mikem53
Drives: FR-S 6MT
It works fine and gives you all the options the dealer gets.. I was able to change a few things and monitor the engine.. Do a search on techstream and get the latest 8.10 download..
Old 08-03-2013, 10:54 AM   #9
Pablitomarrero
Going to have to look into this dammit. Idisconnecting the battery did not work
Old 08-03-2013, 11:43 AM   #10
aagun
Drives: 86
if you remove the airbag , the srs system not work .
aagun is offline   Reply With Quote
Old 08-03-2013, 12:19 PM   #11
Pablitomarrero
I mean the airbagi is back in, the system just recorded the code and left it on there
Old 08-03-2013, 12:23 PM   #12
Anthony
Weight Nazi
Anthony's Avatar
He was probably assuming your new wheel didn't retain the factory airbag since most aftermarket wheels don't.
...I assume.
Old 11-04-2013, 12:38 AM   #13
Trojan_SC
Trojan_SC's Avatar
Drives: '14 Monogram FR-S(RIP)
You didn't spin the clock spring at all right? Because if you did and didn't have it perfectly centered when you reinstalled...$300 mistake.
Trojan_SC is offline   Reply With Quote
Old 04-04-2014, 08:34 AM   #14
alderaan34
alderaan34's Avatar
Did you ever get yours reset? I installed a new turn stalk w/ fog and my light was on afterwards, but the car didn't go into limp mode so I don't think the clock spring is broken, just popped a code that needs cleared.
alderaan34 is offline   Reply With Quote
Airbag light trick for racing seats. Ricepuddin DIY (Do-It-Yourself) Guides 111 03-18-2024 08:05 AM
Side Airbag light with aftermarket seat? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 7 04-09-2014 03:20 PM
exclamation light is on and stays on yellow SuperDave Issues | Warranty | Recalls / TSB 30 04-03-2014 11:48 AM
Airbag Light Delete Juurian Electronics | Audio | NAV | Infotainment 0 06-20-2013 08:37 PM
Airbag light norcal_brz Issues | Warranty | Recalls / TSB 6 03-27-2013 02:59 PM
