Old 01-28-2014, 12:21 PM   #1
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
Courtesy Light Stays On After LED Upgrade
Does anyone have a solution for this? Installed LED courtesy lights and now (several months later) the passenger side light stays on at all times. Closing the door dims the light a bit, but it's still on. Not too worried about the battery, since it's an LED, but it's a problem.
milhouse is offline   Reply With Quote
Old 01-28-2014, 12:31 PM   #2
Diode Dynamics
Diode Dynamics's Avatar
Could you be a little more specific?
Is it staying on at full power, or staying very dimly lit?
Nick C.
John C.
Diode Dynamics
Old 01-28-2014, 12:55 PM   #3
milhouse
Because Racecar
milhouse's Avatar
It's fully lit when the door is open. Closing the door dims it, but it never turns off. Driver side works normally.
Old 01-28-2014, 12:57 PM   #4
xxscaxx
Drives: 2013 SWP BRZ
Take the LED out. Replace it with OEM. If it still does it, the BUI unit needs to be replaced and you have to take it in to the dealer. Same thing happened to me.
xxscaxx is offline   Reply With Quote
Old 01-28-2014, 01:10 PM   #5
Diode Dynamics
I would suggest taking it to the dealer and getting that checked out as well. I've seen BRZ owners bring them in and have it fixed for no charge.
Nick C.
John C.
Diode Dynamics
Old 01-28-2014, 01:11 PM   #6
xxscaxx
Nick C.
Yep, including myself
Old 01-28-2014, 01:19 PM   #7
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
What he said. Put the incandescent bulb back in first and see if it still happens. If the incandescent bulb dims all the way down, then you might need to tap a resistor into the wiring.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 01-28-2014, 02:36 PM   #8
milhouse
Because Racecar
milhouse's Avatar
Thanks. If there is an issue with the BUI, is the dealership going to give me a hard time for replacing the OEM incandescents?
Old 01-28-2014, 02:39 PM   #9
Acree
Acree's Avatar
Personally, I would go to the dealership with the incandescents installed.
Old 01-28-2014, 02:54 PM   #10
Diode Dynamics
I highly doubt it, but if you have LEDs installed, they will probably blame it on that regardless of any factual information about LEDs
Nick C.
John C.
Diode Dynamics
Old 01-28-2014, 03:02 PM   #11
Acree
Acree's Avatar
Precisely. This man knows.
Old 01-28-2014, 03:45 PM   #12
Diode Dynamics
Oh yes, lol trust me
I've heard some pretty good ones....
Customer: My headlights were working before I went into the dealer, now they don't work and the dealer says I need new headlight housings at $alotxxamount
Me: Are the bulbs connected?
Customer: No, nothing is connected to the bulbs
Me: Plug the bulbs back in to see if it works
Customer: My headlights work! Thanks
Me: Dealers unplugged them? Why.... lol
Not all dealers are like this obviously, but it does get frustrating. I hate when they try to take advantage of customers.
Nick C.
John C.
Diode Dynamics
BRZ Driver's Door Courtesy Light Won't Work delusional Issues | Warranty | Recalls / TSB 31 05-29-2022 07:15 AM
Airbag light stays on after removal/reinstallation Pablitomarrero Issues | Warranty | Recalls / TSB 13 04-04-2014 08:34 AM
exclamation light is on and stays on yellow SuperDave Issues | Warranty | Recalls / TSB 30 04-03-2014 11:48 AM
Exterior led strip courtesy light? ft86me Cosmetic Modification (Interior/Exterior/Lighting) 3 08-01-2013 03:50 PM
LED WHITE COURTESY FOOT LIGHT- Group Buy F-T Exterior Parts - Lighting 2 03-04-2013 04:59 AM
