Old 01-24-2015, 04:45 PM   #1
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Rattle after front pipe install
Just installed a tanabe front pipe but I hear slight rattling when I rev the car. Where could it cause this issue? I read about lifting the pipe and tightening?
One bolt from the over pipe snapped too but luckily I still had enough threads for replacement nut.
Edit: problem solved. Over pipe got slightly moved during install. Wiggling it around got it back to no rubbing the subframe
Decimus is offline   Reply With Quote
Old 01-25-2015, 01:49 AM   #2
jflogerzi
jflogerzi's Avatar
Could be the over pipe hitting the subframe?
Old 01-25-2015, 05:24 AM   #3
Mike Brz
Does it have a badge on it. My j2 downpipe had a badge it was rratteling cause the welds broke
Mike Brz is offline   Reply With Quote
Old 01-25-2015, 11:49 AM   #4
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Possibly, I searched more and I think maybe the over pipe is slightly misaligned so going to try to move it and tighten down the front pipe hangar bolt
Nah didn't have a badge. Good looking out though
Old 01-25-2015, 12:05 PM   #5
HotRodPA
Did you reuse the OEM dounut the slips on the downpipe? Forgetting that step caused a rattle in my car. Good luck!
HotRodPA is offline   Reply With Quote
Old 01-25-2015, 02:50 PM   #6
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Problem fixed! Went under the car again and loosened the front pipe hanger and trial & error until I found the "sweet spot" with no metal on metal. It was definitely the over pipe touching the sub frame. Thanks everyone!
Old 01-25-2015, 05:03 PM   #7
jflogerzi
jflogerzi's Avatar
Perfect.
Any NY'ers install catless front pipe? ShoNUFF NY / NJ / CT / PA 19 01-04-2015 08:30 PM
Berk HFC Front Pipe install questions ronboogieon DIY (Do-It-Yourself) Guides 3 11-08-2014 12:40 PM
cel after front pipe install assbox Engine, Exhaust, Transmission 18 11-26-2013 02:02 PM
Catless front pipe install? bdanisi Southern California 7 08-22-2013 08:26 PM
Assistance on DIY front pipe install. Osiris DIY (Do-It-Yourself) Guides 3 04-18-2013 10:31 PM
