Old 04-18-2013, 01:37 AM   #1
Osiris
Osiris's Avatar
Drives: Asphalt FR-S
Assistance on DIY front pipe install.
Hey everyone. I need some help. I have my car up on jack stands and I am attempting to switch out my factory front pipe with an Invidia catless. My questions are as follows:
1. Will I have to remove the fiberglass (looking) shroud that cuts around the resonator in the stock front pipe.
2. Will I have to remove the metal shroud surrounding the bolts for the front pipe connecting to the overpipe/header?
and 3. Should the bolts connecting the front pipe to the header be hard as F*CK to get off? I have the rest of it unbolted but those two in the front are being little pricks and are resisting my man-handling.
P.S. I lift.
Osiris is offline   Reply With Quote
Old 04-18-2013, 01:49 AM   #2
Xdragonxb0i
Drives: ex500r
1. Maybe, i depends if you can reach the bolts, Possibly not.
2.. No,
3. Yes its hard as fuck to remove the overpipe. You need to remove the alluminum plate as well, unbolt the 2 engine mounts and jack up your engine as well. Check out a DIY Header Install thread to get the full details.
Xdragonxb0i is offline   Reply With Quote
Old 04-18-2013, 01:51 AM   #3
husker741
http://www.ft86club.com/forums/showthread.php?t=8121
husker741 is offline   Reply With Quote
Old 04-18-2013, 10:31 PM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
No need to unbolt engine mounts or anything like that.
"With the crosspipe shields removed, the crosspipe has room to be snaked out. It’ll take some trial and error, but trust me, it’ll come out. You’re going to want to pull back and up on the pipe while turning it slightly counterclockwise."
Any NY'ers install catless front pipe? ShoNUFF NY / NJ / CT / PA 19 01-04-2015 08:30 PM
FBM install assistance Gen Forced Induction 23 04-10-2013 10:46 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
MXP EXHAUST and FRONT PIPE FRS BRZ in stock ready to install or ship AMPLIFIED MOTORSPORT Engine, Exhaust, Bolt-Ons 0 11-08-2012 09:09 PM
