BAE
Drives: Asphalt FRS
Rattle after front pipe install
Just installed a tanabe front pipe but I hear slight rattling when I rev the car. Where could it cause this issue? I read about lifting the pipe and tightening?
One bolt from the over pipe snapped too but luckily I still had enough threads for replacement nut. Edit: problem solved. Over pipe got slightly moved during install. Wiggling it around got it back to no rubbing the subframe Last edited by Decimus; 01-25-2015 at 02:53 PM. Reason: solved! |
#2 |
Could be the over pipe hitting the subframe?
#3 |
Does it have a badge on it. My j2 downpipe had a badge it was rratteling cause the welds broke
#4 |
BAE
Drives: Asphalt FRS
Possibly, I searched more and I think maybe the over pipe is slightly misaligned so going to try to move it and tighten down the front pipe hangar bolt
Nah didn't have a badge. Good looking out though |
#5 |
Did you reuse the OEM dounut the slips on the downpipe? Forgetting that step caused a rattle in my car. Good luck!
#6 |
BAE
Drives: Asphalt FRS
Problem fixed! Went under the car again and loosened the front pipe hanger and trial & error until I found the "sweet spot" with no metal on metal. It was definitely the over pipe touching the sub frame. Thanks everyone!
#7 |
| Any NY'ers install catless front pipe? | ShoNUFF | NY / NJ / CT / PA | 19 | 01-04-2015 08:30 PM |
| Berk HFC Front Pipe install questions | ronboogieon | DIY (Do-It-Yourself) Guides | 3 | 11-08-2014 12:40 PM |
| cel after front pipe install | assbox | Engine, Exhaust, Transmission | 18 | 11-26-2013 02:02 PM |
| Catless front pipe install? | bdanisi | Southern California | 7 | 08-22-2013 08:26 PM |
| Assistance on DIY front pipe install. | Osiris | DIY (Do-It-Yourself) Guides | 3 | 04-18-2013 10:31 PM |
