Old 11-08-2014, 06:46 AM   #1
ronboogieon
BReeZy Hunter
ronboogieon's Avatar
Drives: 13 DGM BRZ Limited 6MT
Berk HFC Front Pipe install questions
For those who have had the Berk HFC front pipe installed...
1. Is the included gasket and bolts/nuts for the overpipe/front pipe connection? If so do I need to remove the heat shield?
2. Mine didn't come with the washers shown in the link. Is it necessary and if so what is the size/thickness? Where are they used at?
3. Do you reuse the OEM gasket and hardware for the front pipe/mid pipe connection? Mine didn't come with a drawn picture or instructions.
http://www.berktechnology.com/conten...4-Hardware.jpg
ronboogieon is offline   Reply With Quote
Old 11-08-2014, 11:07 AM   #2
Migero86
Migero86's Avatar
Drives: 2015 Trailhawk
1. OEM Frontpipe has studs and bolts you can reuse to connect this HFC frontpipe, you can feel free to use the new gasket. Thats how mine went on and its fine.
2. Dont need the washers if you reuse the OEM nuts. Thats how mine went on and its fine.
3. OEM Donut gasket for the OEM catback slips off the OEM frontpipe and onto the Berk frontpipe then reattach using spring bolts. Thats how mine went on and its fine.
Migero86 is offline   Reply With Quote
Old 11-08-2014, 11:59 AM   #3
nunonuna
nunonuna's Avatar
I didn't use hardware that Berk sent with FP. I actually was installing PERRIN overpipe together so I used PERRIN harware because Berk harware gave me hard time to fit. I remeber that the nut was bigger (16mm I think) and its catted so not enough clearance for socket or wrench to get in. If I was installing only FP, Im sure I was going to go hardware store to buy better bolt and nut.
nunonuna is offline   Reply With Quote
Old 11-08-2014, 12:40 PM   #4
ronboogieon
BReeZy Hunter
Thanks guys!
$225 Catted Front Pipe from Berk Technology Firestorm_86 Engine, Exhaust, Transmission 35 08-25-2017 08:42 PM
Perrin or Berk catted front pipe JDKane527 Engine, Exhaust, Transmission 22 08-12-2017 02:01 PM
FS: Used Berk Front Pipe w/HFC jordanrw260 Engine, Exhaust, Bolt-Ons 10 05-15-2014 07:51 PM
FS: Berk Catted Front Pipe (NorCal) leicaboss Engine, Exhaust, Bolt-Ons 11 03-20-2014 07:11 PM
Berk Test Pipe (Front pipe cat delete) jeebus Engine, Exhaust, Bolt-Ons 2 02-13-2014 12:14 PM
