Old 11-02-2013, 01:48 PM   #1
assbox
assbox's Avatar
Drives: Whiteout FRS
cel after front pipe install
hey guys.. i installed an invidia catless front pipe just over a week ago. yesterday i got a CEL just after pulling away from a parking lot. the car was already warmed up. the car seemed like it was bogging down right before the CEL went on. once the CEL was on i havnt really felt a difference in drivablility. Should i remove the front pipe to resolve issue? should i take to the dealer to reflash ecu?
Just wondering what you guys would do
IG: ft86carbon
assbox is offline   Reply With Quote
Old 11-02-2013, 01:58 PM   #2
ProTekk
ProTekk's Avatar
Drives: Whiteout FR-S
For $15 you could have bought a Bluetooth OBD 2 reader and the Torque app for android. You can read and clear codes with that. It's a cheap investment for an invaluable tool that will save you time and money. Seriously. This should be a mandatory thing for anyone modifying their car.
Sent from my SM-N900T using Tapatalk
ProTekk is offline   Reply With Quote
Old 11-02-2013, 02:04 PM   #3
assbox
assbox's Avatar
holy sh*t, i didnt think of something like that. PROtip for sure. +1
any recommended applications from your experience?
IG: ft86carbon
Old 11-02-2013, 02:09 PM   #4
ProTekk
ProTekk's Avatar
If you have an Android decice, Torque Pro is the best app out. For the OBD reader, almost any ELM327 bluetooth will work. ELM327 can be found on ebay for $7.99 and Torque Pro will run you $4.99.
Old 11-02-2013, 02:14 PM   #5
ProTekk
ProTekk's Avatar
And don't go to the dealer. They might not care about it but you also may be given a hard time.
Old 11-02-2013, 02:58 PM   #6
DAMotorsports
Drives: 2013 Scion FRS "Raven"
You can also go to autozone and read the code. Did you disconnect the battery after the install?
DAMotorsports is offline   Reply With Quote
Old 11-02-2013, 03:02 PM   #7
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Autozone no longer reads codes as per new California law. Shitty, but true.
Zach3794 is offline   Reply With Quote
Old 11-02-2013, 03:02 PM   #8
assbox
assbox's Avatar
yea im totaly going to avoid the dealer as much as possible. they have already messed up a simple oil change already. im not gonna trust them with much else.
i appreciate the new found knowledge of the tools you have provided, thank you. hopefully ill get this diagnosed asap!
IG: ft86carbon
Old 11-02-2013, 03:04 PM   #9
assbox
assbox's Avatar
i disconnect my battery after the install. i re-connected the battery and left her running for about 5 min. i had no issues for a week. then randomly.. cel. once i saw cel, i disconnected the battery and tried that method again... still cel. so looks like i got some research to do with this app and bluetooth device.
IG: ft86carbon
Old 11-02-2013, 03:28 PM   #10
assbox
assbox's Avatar
n00b question. do you have to remove the ecu to plug in the bluetooth device? or is the port accessible?
IG: ft86carbon
Old 11-02-2013, 03:30 PM   #11
ProTekk
ProTekk's Avatar
No, you can access the OBD port on the right hand side of the driver footwell
Old 11-02-2013, 03:31 PM   #12
ProTekk
ProTekk's Avatar
Just plug it in and forget it. Mine is plugged in 24/7
Old 11-02-2013, 03:36 PM   #13
assbox
assbox's Avatar
beautiful. thanks again protekk!
IG: ft86carbon
Old 11-02-2013, 03:39 PM   #14
ProTekk
ProTekk's Avatar
No problem. Hope it's something simple!
Any NY'ers install catless front pipe? ShoNUFF NY / NJ / CT / PA 19 01-04-2015 08:30 PM
Catless front pipe install? bdanisi Southern California 7 08-22-2013 08:26 PM
Assistance on DIY front pipe install. Osiris DIY (Do-It-Yourself) Guides 3 04-18-2013 10:31 PM
MXP EXHAUST and FRONT PIPE FRS BRZ in stock ready to install or ship AMPLIFIED MOTORSPORT Engine, Exhaust, Bolt-Ons 0 11-08-2012 09:09 PM
