You Made Bro?
Drives: Raven 86
So more issues.
Dealer replaced fuel pump. Now sound is way worse. Any thoughts. Frs Idle is still wrong, if not way worse.: [ame]http://youtu.be/UdLjTn_7Xbs[/ame]
Sent from my SM-G900V using Tapatalk
"Careful though, I've seen many of my friends turn from ironic bros to full on bros by accident." - cfusionpm
could you give us a brief history of what's been going on with your car?
Drives: Subaru BRZ Limited
Sounds like a badly worn throw out bearing on your clutch assembly but that wouldn't have anything to do with your fuel pump.
You Made Bro?
Drives: Raven 86
The history is the clutch always smells burning even when I double clutch. I told them it was the throwout bearing but because this involves tranny labor and it's under warranty they are avoiding but now with this video they have to step up. Aside from the sound which is only in start up and the burning clutch nothing else is wrong. Shifts fine not burning thru more gas this normal no clutch slipping nothing unusual.
Did you do the clutch adjustment DIY?
Drives: 4wd zooks
When they replaced the fuel pump , they might have reset the ecu , which will put it into learning mode.
When mine was put into learning mode , it took about 200 kms to regain throttle response and consistent idle. |
regardless that does NOT sound normal.
not playing cards
I don't know what the hell that is. If it's the throwout bearing you will feel it in the clutch pedal. Do you?
Drives: car
Wow, see this is why I keep my stock fuel pump (orig. 2012) and not let dealerships mess with my car. Everything is fine. They never fixed the chirping on any of their revisions anyway.
#10 |
You Made Bro?
Drives: Raven 86
I did the clutch adjustment. And have heard that may cause issues. But again clutch gas and brake pedals all feel absolutely normal. Throttle response is fine. Again no clutch slipping whatsoever.
#11 |
not playing cards
Not to second-guess your work so, respectfully, are you absolutely certain the clutch master cylinder is releasing (extending) completely when you let go? If you look where the rod goes into it, does the little ball come all the way back to the hard stop?
#12 |
in orbe terrum non visi
Drives: violent
That is 100% throw out bearing. Stop wasting time and throwing ideas out there. Ecu relearn? Seriously? It's the throw out bearing rattling around. When the clutch fork presses against it it can't rattle anymore. I've replaced a few already. It could also be the throughout bearing retainer clips are broken and it's spinning around wildly. If you pull the inspection plate or the dust boot off the transmission you can look in and see.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#13 |
Drives: tezla
wow that sounds really bad
#14 | |
You Made Bro?
Drives: Raven 86
| Oil issues with my avo brz...help!!!!! | brz2013 | Forced Induction | 22 | 10-19-2016 11:03 AM |
| Anyone having oil issues? | Dorb | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 30 | 07-29-2014 04:37 PM |
| Oft e85 issues | sosick | Software Tuning | 14 | 05-22-2014 05:40 PM |
| more issues after CEL fix.. | DrewZ926 | Issues | Warranty | Recalls / TSB | 2 | 11-07-2012 08:15 PM |
| Anybody with no issues? | tdoggy57 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 08-04-2012 03:41 PM |
