Old 09-10-2013, 08:04 PM   #1
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
Oil issues with my avo brz...help!!!!!
I have the avo kit on my brz... No catch can yet but I'm getting oil right to the throttle body...like wayyyy more than just regular blow by. Thought we were getting to much vacuum pulling oil up from the reservoir so we just vented everything to atmosphere to see if that helped but it's still pissing oil out the vent tube. But the car runs fine.... Soooo confused.
brz2013 is offline   Reply With Quote
Old 09-10-2013, 08:06 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Have you vented the PCV, the Reservoir and the breather? All three?
If yes, it could be left over oil from before venting them or turbo seals.
Old 09-10-2013, 10:26 PM   #3
jamesm
If it's as much oil as it sounds like I'd guess turbo oil seal. Or maybe the pcv is leaking back through, pressurizing the crankcase and blowing oil back up through the crankcase breather to the port in front of the intake manifold. My pcv leaked bad under boost without an additional check valve.
Old 09-10-2013, 11:26 PM   #4
brz2013
brz2013's Avatar
Running a mr2 or supra turbo pcv in line...and generally if it's blown turbo seals wouldn't it be smoking bad out the exhaust?.....also we just realized the bov was stuck shut so that's fixed and now after some driving I think the system has blown out the excess oil after being vented to atmosphere.. It's not leaking out the vent tube anymore.. I'm still getting oil blowing out of my boost controller solenoid though...so frustrated
Old 09-11-2013, 08:03 AM   #5
ATSAaron
Drives: 2013 Raven FR-S
Is the oil drain working properly on the AVO kit? If not then there will be too much pressure inside the turbo and it will leak past the turbo seals and into the intake (and exhaust) pipes.
Aaron
ATSAaron is offline   Reply With Quote
Old 09-11-2013, 03:16 PM   #6
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
For what it's worth, I have a lot of experience in dealing with crankcase blow by issues on boxer motors. When I turbocharged my FRS race car I knew I had to eliminate the OEM crankcase ventilation system.
From what I remember there are two crankcase/valve cover breather hoses. If you see on our Competition catch can we vent the main breather into the -12 in our air/oil separator (block fitting was removed and a -12 port threaded into block) and then the other hose next to the throttle body was directed to the other -10 fitting on our can. No PCV is used.
All crankcase ventilation now vents to atmosphere. Even at 400 whp, slick tires, and huge downforce, I'm not getting hardly any oil blow by in to the catch can. Subaru has definitely improved the oil control on this motor as we have serious issue with the EJ motor puking out the breathers (heads an crankcase).
I suspect and I hate to say this, but based on what my motor is doing at high power vs. yours, you may have a cracked piston ringland. This would cause the excessive pressure in the crankcase.
Make sure you have your hoses correctly vented and nothing from your charge pipe is going into either crankcase breather.
Last edited by Element Tuning; 09-11-2013 at 04:44 PM. Reason: Edited for PCV Valve notes
Element Tuning is offline   Reply With Quote
Old 09-11-2013, 03:17 PM   #7
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Add a photo of your setup. From the sound of it you are running the stock pcv and setup which could be part of your problem, but without a photo to see how you have everything setup it will be hard to narrow down
DAMotorsports is offline   Reply With Quote
Old 09-11-2013, 06:48 PM   #8
brz2013
brz2013's Avatar
I sure hope that's not the case !!! If I was getting excessive pressure like that wouldn't it blow out the dipstick?
Old 09-11-2013, 08:35 PM   #9
brz2013
brz2013's Avatar
Pretty sure I've isolated it to the breather off the oil reservoir....is that good news
Old 09-11-2013, 08:39 PM   #10
Sportsguy83
Drives: Limited BRZ
As long as neither the block breather or the PCV are pouring oil out, then yeah thats good news.
Old 09-11-2013, 09:52 PM   #11
brz2013
brz2013's Avatar
Yep. Only the reservoir vent tube now that it's isolated . Still shouldn't be happening but at least it's not my motor....avo oil pump might not be working properly...will troubleshoot and update tomorrow
Old 09-12-2013, 11:52 AM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Please take pictures of exactly how you have everything configured currently. My best guess at this point is still the turbo oiling system. Your best bet would be to check with AVO on how much oil flow the turbo should be seeing and then pull your return line off and see how much flow you are getting.
Old 09-12-2013, 11:53 AM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Nice to see you guys recommending a VTA catch can. I also love that gold wrapping on your intake pipe. Did you do any before or after testing to see if it helped? I have considered doing it to mine.
Old 09-14-2013, 12:10 AM   #14
brz2013
brz2013's Avatar
All solved.... Special thanks to element tuning and sportsguy83
Bluetooth issues? zoomzoomers Electronics | Audio | NAV | Infotainment 12 04-27-2013 02:35 AM
Anybody Have Zero Issues? Don Ivey Scion FR-S / Toyota 86 GT86 General Forum 129 03-25-2013 01:14 PM
91 Octane issues? tokiokun717 Northern California 17 02-01-2013 02:21 PM
more issues after CEL fix.. DrewZ926 Issues | Warranty | Recalls / TSB 2 11-07-2012 08:15 PM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 03:41 PM
