Drives: 16 LM STI/13 LM BRZ/04 AVALANCHE
Anyone having oil issues?
Read this the other day about Subaru being sued over burning excess oil. Does not mention BRZ but does mention the Crosstrek with what I believe to be our engine.
http://www.usatoday.com/story/money/...suit/12859865/ |
Off Topic
I wonder what's considered excessive loss of oil? All the subarus I've had have burned oil, that's just the nature of the beast. From reading that article it sounds drastic though, like they're losing half of their oil in 3K miles.
#3 | |
1 quart over 3,000 miles. Edit: with regards to the Toyobaru I'm at about 30,000 miles and I haven't noticed any consumption, it may be happening but not enough to warrant me topping off over the 7,500 mile interval. Last edited by strat61caster; 07-21-2014 at 07:57 PM. |
Drive From Home
Drives: BRZ STI Performance
FA20 doesn't burn oil from what I have gathered. Factory fill changed at 4800km and Eneos Sustina 0W-20 since, now at 8800km and no oil burning.
Drives: BRZ DGM Limited
nothing here either, but I wonder if that is the reason they shortened the oil change intervals in the 2015 BRZ?
Drives: 2013 Asphalt Fr-S
Both of the vehicles mentioned in the article use the FB20 motor (Still a 2.0L but modified from our FA20)
Drives: 14 BSP Edelbrock BRZ
Can't believe Imprezas weren't on that list. Subaru spec is 1 quart/1500 miles is okay!!
Drives: '13 BRZ, '06 997, Other Things(TM)
Oil consumption on mine varies a lot based on usage. If i drive it hard I'll burn almost a quart per thousand miles. If I just do highway miles, not so much. When driving it hard you definitely need to keep an eye on your fluid levels.
Mines burned about a quart every 1.5-2K miles the first ~30K miles.. now I only burn about HALF a quart every 3-4K miles.
Not that it's relevant, but I used Amsoil 0W-20 the first ~25K miles, then switched to Gastrol.. just switched again to Pennzoil. |
#10 |
Drives: Currently 2018 Taco
#11 |
Drives: fr-s
#12 | |
Out of curiosity how did you do your break in? I've had a couple hard days, on about 6,000 miles on this oil and still right about where I put it (+/-5% depending on conditions during check) |
#13 |
No consumption here. 12k miles now. Changed to Redline 0w20 at 1k miles, changed to M1 0w20 at 8k.
#14 | |
Ironically, a thread began at Subaruforester.org about this back in 2011 about the 2011 model year Foresters and that model year was not even part of the oil control ring TSB referenced in the article. |
| Oil issues with my avo brz...help!!!!! | brz2013 | Forced Induction | 22 | 10-19-2016 11:03 AM |
| Oft e85 issues | sosick | Software Tuning | 14 | 05-22-2014 05:40 PM |
| Anybody Have Zero Issues? | Don Ivey | Scion FR-S / Toyota 86 GT86 General Forum | 129 | 03-25-2013 01:14 PM |
| more issues after CEL fix.. | DrewZ926 | Issues | Warranty | Recalls / TSB | 2 | 11-07-2012 08:15 PM |
| Anybody with no issues? | tdoggy57 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 08-04-2012 03:41 PM |
