Old 11-24-2014, 03:44 PM   #1
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
So more issues.
Dealer replaced fuel pump. Now sound is way worse. Any thoughts. Frs Idle is still wrong, if not way worse.: [ame]http://youtu.be/UdLjTn_7Xbs[/ame]
Sent from my SM-G900V using Tapatalk
"Careful though, I've seen many of my friends turn from ironic bros to full on bros by accident." - cfusionpm
bdanisi is offline   Reply With Quote
Old 11-24-2014, 04:33 PM   #2
Koa
could you give us a brief history of what's been going on with your car?
Old 11-24-2014, 04:59 PM   #3
JoeC
Drives: Subaru BRZ Limited
Sounds like a badly worn throw out bearing on your clutch assembly but that wouldn't have anything to do with your fuel pump.
JoeC is offline   Reply With Quote
The Following 2 Users Say Thank You to JoeC For This Useful Post:
aagun (12-03-2014), DieselDog (11-27-2014)
Old 11-24-2014, 07:24 PM   #4
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
The history is the clutch always smells burning even when I double clutch. I told them it was the throwout bearing but because this involves tranny labor and it's under warranty they are avoiding but now with this video they have to step up. Aside from the sound which is only in start up and the burning clutch nothing else is wrong. Shifts fine not burning thru more gas this normal no clutch slipping nothing unusual.
Old 11-24-2014, 07:47 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Did you do the clutch adjustment DIY?
Old 11-24-2014, 09:58 PM   #6
alan.chalkley
Drives: 4wd zooks
When they replaced the fuel pump , they might have reset the ecu , which will put it into learning mode.
When mine was put into learning mode , it took about 200 kms to regain throttle response and consistent idle.
alan.chalkley is offline   Reply With Quote
Old 11-24-2014, 10:13 PM   #7
Koa
regardless that does NOT sound normal.
Old 11-24-2014, 10:21 PM   #8
I don't know what the hell that is. If it's the throwout bearing you will feel it in the clutch pedal. Do you?
Teseo (11-24-2014)
Old 11-24-2014, 10:42 PM   #9
radroach
Drives: car
Wow, see this is why I keep my stock fuel pump (orig. 2012) and not let dealerships mess with my car. Everything is fine. They never fixed the chirping on any of their revisions anyway.
Old 11-25-2014, 01:33 PM   #10
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
I did the clutch adjustment. And have heard that may cause issues. But again clutch gas and brake pedals all feel absolutely normal. Throttle response is fine. Again no clutch slipping whatsoever.
Old 11-25-2014, 02:07 PM   #11
Not to second-guess your work so, respectfully, are you absolutely certain the clutch master cylinder is releasing (extending) completely when you let go? If you look where the rod goes into it, does the little ball come all the way back to the hard stop?
strat61caster (11-25-2014)
Old 11-25-2014, 02:21 PM   #12
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
That is 100% throw out bearing. Stop wasting time and throwing ideas out there. Ecu relearn? Seriously? It's the throw out bearing rattling around. When the clutch fork presses against it it can't rattle anymore. I've replaced a few already. It could also be the throughout bearing retainer clips are broken and it's spinning around wildly. If you pull the inspection plate or the dust boot off the transmission you can look in and see.
The Following 4 Users Say Thank You to Reaper For This Useful Post:
bdanisi (11-26-2014), DieselDog (11-27-2014), strat61caster (11-25-2014), Ultramaroon (11-25-2014)
Old 11-25-2014, 09:17 PM   #13
frs10
Drives: tezla
wow that sounds really bad
frs10 is offline   Reply With Quote
Old 11-26-2014, 02:28 AM   #14
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
I specifically told the dealer it was the throwout bearing but they decided to install a 2000 dollar fuel pump. I've told them ten times but they don't seem to get it. If they can't fix it then I'm going to Alex at fuzion teknique Gardena and have him do it. Is the part and or labor expensive? Also I didn't do the clutch alone. My friend told me everything was extending perfectly fork joints etc all were fine. And I did that like... 25k miles ago
The Following User Says Thank You to bdanisi For This Useful Post:
Ultramaroon (11-26-2014)
Oil issues with my avo brz...help!!!!! brz2013 Forced Induction 22 10-19-2016 12:03 PM
Anyone having oil issues? Dorb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 07-29-2014 05:37 PM
Oft e85 issues sosick Software Tuning 14 05-22-2014 06:40 PM
more issues after CEL fix.. DrewZ926 Issues | Warranty | Recalls / TSB 2 11-07-2012 09:15 PM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 04:41 PM
