Old 11-04-2014, 04:14 PM   #1
Thataznguy001
Drives: Whiteout FRS 2014
Question about lowering and tire fitments
Hi I was wondering if anybody can give me any insights on a couple of clearance issues,
I'm planning on running a square setups with enkei raijin 18.9.5 +45. I was reading somewhere that you need to be lowered on coils or springs for at least 1.5 inch for no clearance issue? Tire size that I'm planning is 255/35/r18 all four.
would this set up work for stock springs and stock suspension?
If i have to resort to coils or springs what would be my best choice? I'm thinking about RSR super down springs for the time being.
Any advice is appreciated.
Thataznguy001 is offline   Reply With Quote
Old 11-04-2014, 08:14 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
http://www.ft86club.com/forums/showthread.php?t=35463
There is infoinformation that pertains to your setup. Don't think springs and 255 will work in the front. Requires coils.
Old 11-04-2014, 08:46 PM   #3
8R6
8R6's Avatar
Drives: FRS
that will rub with just lowering springs. you'll need coilovers to get clearance. besides, whats the point of having 255 tires and 9.5 wheels on a stock set up? thats too much tire and will just slow down your car
8R6 is offline   Reply With Quote
Old 11-06-2014, 06:47 AM   #4
Thataznguy001
thanks for the input, so would it clear on a 17x9 +45 all around set up on stock susps and maybe some springs?
Old 11-06-2014, 06:54 AM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
This guy said he needs 3mm spacer to clear 17x9 +45
http://www.ft86club.com/forums/showthread.php?t=48453
This guy running what you want but has coilovers
http://www.ft86club.com/forums/showthread.php?t=63268
Old 11-06-2014, 03:44 PM   #6
Thataznguy001
[QUOTE=ZionsWrath;2012491]This guy said he needs 3mm spacer to clear 17x9 +45
so if i were to run his setup
would these spacers do the trick for the front?
[ame="http://www.amazon.com/Macht-Schnell-Competition-Wheel-Spacer/dp/B00MQWLKIQ/ref=sr_1_2?ie=UTF8&qid=1415306621&sr=8-2&keywords=3mm+spacer"]Amazon.com: Macht Schnell Competition Wheel Spacer Kit - 3mm Hubcentric Spacers + Black Extended 12mm Lug Bolts: Automotive[/ame]
Old 11-06-2014, 03:57 PM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
[quote=Thataznguy001;2012989]
those look like bolts for german cars, I don't think they are studs.
Old 11-06-2014, 04:18 PM   #8
phrosty
18x8+45 wheels will *just* clear the stock suspension. with 8.5" you might need a small spacer up front, and definitely with 9".
9" wheels will look a little weird if it's not lowered, and provide way too much grip for a stock car. It'll slow you down.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 11-06-2014, 04:27 PM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
18x8.5 + 45 with 235/40/18 clears fine with oem camber bolts
Old 11-07-2014, 12:47 PM   #10
BRZ21
i kill cones.
BRZ21's Avatar
Drives: around cones in a parking lot
i have enkei kojins with the same specs, 18x9.5 in the rear and 18x8.5 up front.
stock suspension
the rear fit fine, the fronts have less than a pinky width of space between the tire and spring.
18x9.5 wont fit up front with a narrower spring
2013 SSM BRZ Limited 6MT
BRZ21 is offline   Reply With Quote
Rubber/Tire Sound after lowering springs JohnAyySays Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2014 08:16 PM
Lowering Springs Question Ymerej Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-22-2014 09:24 PM
Question about wheel fitments wilfredwong Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-14-2013 10:53 AM
Wheel and tire fitments, help needed please! THE_FRS_KID Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 05-07-2013 01:27 PM
Lowering Question Vides990 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-20-2013 03:23 AM
