Drives: Scion FR-S Whiteout
Rubber/Tire Sound after lowering springs
Hey Guys! So I've recently installed the eibach prokit springs on my frs and I've heard no clunking sounds over bumps/speed bumps. Recently going up my driveway I've started to hear a noise that sounds like rubber rubbing against each other. Before when I used to go up my driveway I had to fully turn my wheel to get up which caused my passenger rear wheel to lift up. Because I'm lowered would that cause the tire to make that noise? I only hear that noise on my passenger rear wheel. Thanks again!
Señor Member
Did you get an alignment after you installed the new springs?
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | JohnAyySays (09-01-2014) |
Thanks
You say you hear rubbing? You don't say what wheel and tire sizes you have
How can we help? If you hear rubbing... It's rubbing...
| The Following User Says Thank You to ZionsWrath For This Useful Post: | JohnAyySays (09-01-2014) |
@Turdinator not at the moment waiting on springs to settle @ZionsWrath stock tires and wheels sorry. Not sure if it's rubbing but it sounds like when you were to lift your car on jacks and you slowly lifting up the tire from the ground
Sent from my iPhone using Tapatalk Last edited by JohnAyySays; 09-01-2014 at 12:13 PM. |
Drives: Used to Drive:Grand-Am GS #54 E36M3
Did you take the wheel/tire off the car to see if you could see any signs of rubbing, either on the tire itself or on the car?
Another way to check for tire rubbing is to mark the tire in question with tire chalk and then check to see if it's been smudged or disturbed in a way that would indicate rubbing. |
| The Following User Says Thank You to dradernh For This Useful Post: | JohnAyySays (09-01-2014) |
#6 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
| Rubber Plug For Sound Generator Tee | Uniquedetail | DIY (Do-It-Yourself) Guides | 4 | 08-20-2014 10:10 PM |
| Window rubber seal causing squeaking sound? | l0aded | Issues | Warranty | Recalls / TSB | 4 | 08-15-2014 03:08 PM |
| Rubber Tire Mark Cleaner | ryuusei | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 7 | 05-27-2013 05:21 PM |
| Remove tire rubber off car paint (Opti coat applied) | Nardi330 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 11-16-2012 11:18 PM |
| Rubber Plug for Sound Generator Tee | Uniquedetail | Engine, Exhaust, Transmission | 3 | 10-10-2012 11:18 AM |
