Drives: 2013 Subaru BRZ
where to hook up water temp
I'm installing my water temperature sensor tomorrow and I don't know whether to install it before or after the radiator. I feel like before the radiator would give me a better readout of what the engine is actually dealing with for heat issues, but on the other side I can also see why it would be important to see what the temperature is that engine is about to use.
There is already a coolant temperature sender, you should see if you can just tap into it.
You don't want the sender anywhere associated with the rad, you want it inside the coolant loop with the thermostat closed so you're always getting an accurate reading, not just when the thermostat is open. In the block is ideal since that's the actual temperature inside the engine, and that's where the OEM sender is IIRC.
| The Following User Says Thank You to wparsons For This Useful Post: | mikepaul21 (10-25-2014) |
#3 | |
not playing cards
do it via software so you don't fuck up the impedance of the sensor circuit.
Or does someone know if there's a buffer amp in the sensor itself?
I would see if you can return it and find something that ties into the factory stuff.
Alternatively, if you have manual gearbox I think there's a spare plug in the block you can remove to add another sensor, but maybe that's on an oil passage?
Drives: 2013 subaru limited wrb brz
I purchased a prosport radiator hose adapter and cut into the hose that runs from the filler to the block. Temp sending unit screws into the adapter.
http://prosportgauges.com/water-temp...e-adaptor.aspx
![]() Portland 86ers |
| The Following User Says Thank You to wrohdejr For This Useful Post: | mikepaul21 (10-26-2014) |
not playing cards
That's for the clutch throwout fluid.
Sarasm?
There's definitely an extra plug in the engine block on manual cars, just can't remember if it's coolant or oil.
#10 | |
not playing cards
I know about the one under the A/C compressor but was unaware of any other only for the manual.
#11 | |
#12 |
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
It's oil. That's why it leaks oil from tere on some cars lol.
#13 |
Drives: 2014 SWP BRZ, MT
The port above the block next to the AC compressor is oil. There is one for manual transmissions below the block next to the outlet going to the heater core that's plugged on MT models and is coolant. I used that line for my OEM oil cooler's water line. It's right near the water pump. This port is used on AT models for cooling the AT. As suggested using the factory water temp reading would be best but if you want to go this path, you'll also need an adapter for whatever sender you need to plug into that port. The thread in the block is M14x1.5
![]() Picture stolen from the FXT oil cooler DIY page: http://www.ft86club.com/forums/showthread.php?t=50427 |
| The Following User Says Thank You to zkv476 For This Useful Post: | jcw99 (01-17-2015) |
#14 | |
| The Following User Says Thank You to wrohdejr For This Useful Post: | mikepaul21 (11-06-2014) |
| FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) | AtlasMick | Interior Parts (Incl. Lighting) | 2 | 03-31-2015 06:47 PM |
| Water temp. | Reaper | Engine, Exhaust, Transmission | 7 | 08-28-2014 11:20 PM |
| STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB | ziptiedae86 | Interior Parts (Incl. Lighting) | 0 | 10-30-2013 12:50 AM |
| water temp | driver01 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 30 | 04-11-2013 03:57 AM |
| A/C Oil/Water temp gauge | Exhaust | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 02-07-2013 02:19 PM |
