Old 07-08-2012, 05:20 PM   #1
driver01
Drives: brz 13
water temp
water temp
driver01 is offline   Reply With Quote
Old 07-10-2012, 09:46 PM   #2
getbent
Drives: 2013 FR-S Blue MT
Thanks for the info. How long does it take for the coolant and oil temperatures to get up temperature from a cold start in normal driving?
getbent is offline   Reply With Quote
Old 07-10-2012, 10:03 PM   #3
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
was the track driving 30 mintues consecutively or with breaks in between? was 118c the highest oil temp you saw? It seems believable and also suggests that this car has very efficient fluid cooling systems.
Funny how Greddy Japan came out saying they saw 140C oil temps at the track as justification for one of their oil cooler kits. Typical marketing lies!
spiller is offline   Reply With Quote
Old 07-11-2012, 01:47 AM   #4
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Stick with the 0w-30. You need the big number to higher not the little number. There's no point in sacrificing engine-start-wear to improve racing protection.
Old 07-11-2012, 07:25 PM   #5
driver01
Drives: brz 13
at similar ambient temperatures 20 to 30 deg celsius. It takes about 5 minutes for coolant to reach 90 celsius (operating temperature) and it takes oil another 5 minuters (total of 10 minutes to reach 90 celsisus)
warms up very quickly. I say 10 to 15 minutes for a fully warm engine
Old 07-11-2012, 07:28 PM   #6
driver01
Drives: brz 13
I will usually do 30 - 45 minute stints. then let the car rest and cool down for another 30 to 45 minutest before I go back to lapping.
118 was the highest oil temperature reached during the session that I pushed the car the most, basically keeping rpm between 5 and 7 for 30 minutes non stop.
Old 07-11-2012, 07:31 PM   #7
driver01
Drives: brz 13
you make a good point. I have this idea (not confirmed) that at summer temperatures oil thickness should not be an issue when starting (between a 0wxx vs a 5wxx)
for winter driving (it gets quite cold over here) i will be using 0w20
during the summer months I am more concerned about oil viscosity at high temperatures since you are usually running at very high rpm.
Old 07-11-2012, 09:38 PM   #8
rice_classic
You are right that it's not an issue, but at some level (minor as it may be) you will be increasing start-up wear.
This sounds strange but we're talking about "flow". The cSt of 0w (when cold) is closer to the 30 when it's hot. The 5w when it's cold if thicker than the 0w.
Let's use a 0w-20 and a 5w-20 for example and we'll use "startup temp" as 75F and "operating temp" as 212F. Flow is measured in cSt, the higher the number the thicker the oil and the less "flow".
A 0w-20 starts at 40 cSt then becomes 8 cSt at 212F.
A 5w-20 starts at 50 cSt then becomes 8 cSt at 212F.
So we know that the 40 cSt is still too thick to provide adequate flow and protection until it heats up and thins out a bit, but the distance between 40 cSt and 8 cSt is less than 50 is to 8. Thus the 0w decreases start-up wear more than 5w because the 0w will thin to an appropriate cSt before the 5w will.
There is absolutely no point in increasing the little number in a street car application (and most race car applications depending type of racing) unless you're stranded doing an oil change "Billy Bob's truck stop" doesn't have a 0w-XX oil.
Old 07-11-2012, 09:52 PM   #9
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
What hardware/software are you using? I can't seem to oil temp readings.
Old 07-11-2012, 10:53 PM   #10
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Interested to know this as well, wouldn't mind hooking up my laptop just to see what kind of data you can get out of that OBDII port!
Rossman is offline   Reply With Quote
Old 07-12-2012, 05:23 AM   #11
driver01
Drives: brz 13
Techstream lite. Its spedified for dealers and such
https://techinfo.toyota.com/techInfo...ite&_nfpb=true
I also tried a generic reader (plx wifi and dashcommand) very little info out of the ecu (compared to all the data from techstream)
Old 07-12-2012, 08:55 AM   #12
neutron256
neutron256's Avatar
Ah that would explain it. I'm using Torque with OBDLink MX which pulls back a lot but oil temp is one that I'm missing and would very much like. I wish they would make PID info more available so we could manually add them in.
Old 07-12-2012, 07:22 PM   #13
Rossman
Rossman's Avatar
Holy shit, $1300??? That's a bit rich for my blood.
Old 07-12-2012, 07:53 PM   #14
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Would you happen to know the cSt for the 0W20 and 0W30 at the hottest temp op is reaching (118C = ~244F)?
brz7400 is offline   Reply With Quote
Water in reverse lights roddy Scion FR-S / Toyota 86 GT86 General Forum 30 05-09-2013 09:18 AM
Need Detailer Advice re: Water spots on glass Draco-REX Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 39 03-16-2013 07:13 AM
Hard water spots Double4Free Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 07-01-2012 10:14 AM
