Old 08-27-2014, 11:23 PM   #1
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Water temp.
Ecutek is accurate and the obd2 temp (obviously) gives me the right temp but my factory temp gauge never goes past a certaint point. I noticed it awhile back when I had a fan malfunction and despite high temps the gauge never even passed the halfway point. Thankfully I was monitoring it in other ways. But I haven't been able to figure out why my factory gauge is so far off. Anyone else experience this and have a fix?
Old 08-28-2014, 01:09 AM   #2
Falcon
Drives: WRB BRZ
Works as intended
Factory gauges for Fuel and Water Temp are pretty useless.
Falcon is offline   Reply With Quote
Old 08-28-2014, 02:20 AM   #3
Turdinator
Señor Member
Turdinator's Avatar
How high did the temps get? The factory guage won't move in a linear fashion to water temp. It will stay halfway over a temp range say from 175 - 250 etc (those are made up numbers) It may as well be a dummy light.
1974 TA22 Celica
2013 86 GT
Old 08-28-2014, 02:58 AM   #4
Guillaume
Guillaume's Avatar
Drives: Exige S 240
The fix would be an additional gauge. This works great for me : http://www.ft86club.com/forums/showt...ight=Pivot+DXW
Old 08-28-2014, 04:10 PM   #5
Reaper
Reaper's Avatar
Drives: violent
Guys I understand. What im trying to figure out is does the voltage from the sensor go through a resistor or something before going to the gauge? Some cars do this to prevent fluctuations on the gauge and I think ours does. I just don't know how it works in our car.
The sensor varies voltage and the gauge moves based on voltage so there should be a way to make it function more accurately. I was hoping we could figure out how.
Temp was 230 according to water temp gauge and ecutek but oem gauge was still below half where it always was. Im sure another few degrees and it would have swung full into the red. But if the ecutek can see an accurate temp then theres a way to get the gauge to do it as well.
Old 08-28-2014, 04:14 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Mine always seemed accurate. I saw it rise past half way and then back down again while in traffic.
Old 08-28-2014, 07:21 PM   #7
Turdinator
Señor Member
Turdinator's Avatar
I think you will find the guage is controlled by the ECU and not a direct wire to the sensor.
1974 TA22 Celica
2013 86 GT
Old 08-28-2014, 10:20 PM   #8
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
If in the event of a radiator blow and an engine overheat or possible engine seize, and there was a faulty gauge at play would the warrenty cover that?
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
Low Temp Thermostat Roadcone Engine, Exhaust, Transmission 21 12-28-2014 07:36 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 02:57 AM
A/C Oil/Water temp gauge Exhaust Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 01:19 PM
