Old 10-25-2014, 09:31 PM   #1
mikepaul21
mikepaul21's Avatar
Drives: 2013 Subaru BRZ
where to hook up water temp
I'm installing my water temperature sensor tomorrow and I don't know whether to install it before or after the radiator. I feel like before the radiator would give me a better readout of what the engine is actually dealing with for heat issues, but on the other side I can also see why it would be important to see what the temperature is that engine is about to use.
mikepaul21 is offline   Reply With Quote
Old 10-25-2014, 10:12 PM   #2
wparsons
wparsons's Avatar
There is already a coolant temperature sender, you should see if you can just tap into it.
You don't want the sender anywhere associated with the rad, you want it inside the coolant loop with the thermostat closed so you're always getting an accurate reading, not just when the thermostat is open. In the block is ideal since that's the actual temperature inside the engine, and that's where the OEM sender is IIRC.
flickr
mikepaul21 (10-25-2014)
Old 10-25-2014, 10:46 PM   #3
mikepaul21
mikepaul21's Avatar
anyone have any pictures of where I can find this?
Old 10-25-2014, 10:55 PM   #4
do it via software so you don't fuck up the impedance of the sensor circuit.
Or does someone know if there's a buffer amp in the sensor itself?
Old 10-26-2014, 05:50 AM   #5
mikepaul21
mikepaul21's Avatar
I already bought the gauge and it's hardwired, not connected to the OBD 2
Old 10-26-2014, 04:23 PM   #6
wparsons
wparsons's Avatar
I would see if you can return it and find something that ties into the factory stuff.
Alternatively, if you have manual gearbox I think there's a spare plug in the block you can remove to add another sensor, but maybe that's on an oil passage?
flickr
Old 10-26-2014, 06:38 PM   #7
wrohdejr
Drives: 2013 subaru limited wrb brz
I purchased a prosport radiator hose adapter and cut into the hose that runs from the filler to the block. Temp sending unit screws into the adapter.
http://prosportgauges.com/water-temp...e-adaptor.aspx
Portland 86ers
wrohdejr is offline   Reply With Quote
The Following User Says Thank You to wrohdejr For This Useful Post:
mikepaul21 (10-26-2014)
Old 10-26-2014, 07:15 PM   #8
That's for the clutch throwout fluid.
Old 10-26-2014, 07:41 PM   #9
wparsons
wparsons's Avatar
Sarasm?
There's definitely an extra plug in the engine block on manual cars, just can't remember if it's coolant or oil.
flickr
Old 10-26-2014, 08:36 PM   #10
Sarasm?
Oh, just mixing it up. All about clutches for me this weekend
I know about the one under the A/C compressor but was unaware of any other only for the manual.
Old 10-26-2014, 09:10 PM   #11
mikepaul21
mikepaul21's Avatar
Is it the same hose used in in this link? http://www.autometer.com/techinfo_ne...px?pg=1&aid=19
Old 10-26-2014, 09:44 PM   #12
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Sarasm?
It's oil. That's why it leaks oil from tere on some cars lol.
FRSfan111 is offline   Reply With Quote
Old 10-28-2014, 05:26 PM   #13
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
The port above the block next to the AC compressor is oil. There is one for manual transmissions below the block next to the outlet going to the heater core that's plugged on MT models and is coolant. I used that line for my OEM oil cooler's water line. It's right near the water pump. This port is used on AT models for cooling the AT. As suggested using the factory water temp reading would be best but if you want to go this path, you'll also need an adapter for whatever sender you need to plug into that port. The thread in the block is M14x1.5
Picture stolen from the FXT oil cooler DIY page: http://www.ft86club.com/forums/showthread.php?t=50427
zkv476 is offline   Reply With Quote
The Following User Says Thank You to zkv476 For This Useful Post:
jcw99 (01-17-2015)
Old 10-28-2014, 07:16 PM   #14
wrohdejr
No i tapped into the hose from the filler neck to the block.
Portland 86ers
mikepaul21 (11-06-2014)
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
Water temp. Reaper Engine, Exhaust, Transmission 7 08-28-2014 10:20 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 02:57 AM
A/C Oil/Water temp gauge Exhaust Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 01:19 PM
