Old 11-25-2013, 12:52 PM   #1
350matt
Drives: toyota mr2/ Toyota GT86
OEM cats only ?
Chaps
would I be right in saying that its no longer legal to run an aftermarket cat unless the vehicle is either out of warrenty or is over 80K miles?
http://www.dec.ny.gov/chemical/90781.html
Does this apply to CA and New York only?
350matt is offline   Reply With Quote
Old 11-25-2013, 01:44 PM   #2
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Everything is illegal..... But that's a different topic.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 11-25-2013, 02:00 PM   #3
pche
Guy on internet
Drives: Slowly
UK and US laws are different, in US every county in every state has different emission regulations.
pche is offline   Reply With Quote
Old 11-26-2013, 03:16 AM   #4
350matt
So does this only effect CA and NY and in every other state its OK ?
Old 11-26-2013, 03:21 AM   #5
SigmaHyperion
Drives: 2013 SWP BRZ Limited
Under federal law, it is illegal to remove your OEM catalytic converters. It's not a new thing, it's been that way for nearly 25 years.
The only thing that aftermarket hi-flow cats get you, are sufficient emissions control to pass inspections. They're still technically an illegal mod if anyone wanted to crawl under the car and check.
SigmaHyperion is offline   Reply With Quote
Old 11-26-2013, 06:48 PM   #6
jm1681
Drives: MKVI VW GTI
So, the ten-million dollar question, any benefit to cut-and-weld parts (Headers specifically), reusing the OEM cats?
jm1681 is offline   Reply With Quote
Old 11-26-2013, 07:01 PM   #7
jamesm
no. if you don't mind the smell and noise, go catless. if you do, get a high flow cat. if you live in a state that cares about that sort of thing, your probably breaking the law in either case. just keep the stock stuff for inspection time .
Old 11-26-2013, 07:30 PM   #8
Bonks86
Drives: Gt-86
I believe borla themselves posted "federal law" a while back that states removing/replacing any stock cat with anything but OEM is considered illegal, unless of course it is track use...
Bonks86 is offline   Reply With Quote
Gutting out the stock cats diss7 Engine, Exhaust, Transmission 90 04-02-2018 12:57 AM
Just replacing the stock cats? brillo Engine, Exhaust, Transmission 4 07-08-2015 11:12 AM
Motiv Concepts High Flow Cats and Test Pipes MotivConcepts Engine, Exhaust, Bolt-Ons 205 06-12-2013 12:05 AM
I giggled... Cats have it made seven Off-Topic Lounge [WARNING: NO POLITICS] 51 12-21-2012 03:46 PM
Speed cats (or other driving shoes) Symbiont Off-Topic Lounge [WARNING: NO POLITICS] 25 06-14-2012 11:10 PM
