Drives: AE86, 2x GT86, TE27
Gutting out the stock cats
Has anyone gutted out the stock cats?
We used to do this back in the day, and it was always a cheap gain. Admitidly on 10 year old cars with clogged cats. But, would be interested if someone has tried this. Might get 50% of the gains of a $2000 exhaust system for 1 hours work on a hoist. I like the idea of it, from a stealth/sleeper point of view. |
You'll get better gains from larger diameter piping than from just gutting the cats in the stock header/front pipe. I would bet you get less than 1-2hp from gutting the stock cats but without replacing anything else.
#3 | |
Drives: Raven FR-S 6M
“The World is Flat”
[||•]=(86)=[•||] |
You will most likely lose or not gain any power. Your better off with a straight through same diameter pipe. The hollow cat will disrupt the exhaust flow and scavaging effect.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
Drives: 13 White MT FR-S
I did this to my front pipe. Louder, and engine seems smoother. Especially at higher rpms
Drives: Sterling BRZ Ltd
Punching out the cat and inserting a pipe the same diameter of the main pipe could probably show a small gain.
Good luck getting a pipe through the cat on either the header or the front pipe, too many bends in there.
Scrape Master
Drives: Goal: Oldest FRS State Side
you wont see any gains gains going any bigger then 2.5 if you stay NA.
Waste of time and ozone, get high flow cat and larger diameter piping.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#10 |
Seeing as this will cost nothing, I hardly see how it is a waste of time.
#11 |
Understand. But, going for sleeper install. Replacing cat with shiny new decat pipe, is a give away. Gutted out stock cat will still look stock.
#12 |
is better than you
Drives: 2013 raven FRS
how many cats do our cars have? 1 header, 1 over pipe, and is there one in the downpipe as well? Ugh i miss only having 1-2 cats being only in the downpipe..
#13 | |
There are ways & means around this CEL, but there is mixed reviews on the success of these methods. Of cuorse you could get a flash/tune to solve this. The one in the front pipe is not measured in this way, and can be removed without issue. I'm all about keeping my 5 year warranty. Also, we have to get our cars inspected yearly, and they love failing modified cars. |
#14 | |
is better than you
| Gutting primary cat? | jordanrw260 | Engine, Exhaust, Transmission | 6 | 07-30-2018 10:24 PM |
| Just replacing the stock cats? | brillo | Engine, Exhaust, Transmission | 4 | 07-08-2015 11:12 AM |
| Gutting the BRZ and putting in a Electric Engine? | mechaghost | BRZ First-Gen (2012+) — General Topics | 22 | 07-31-2014 07:12 PM |
| I giggled... Cats have it made | seven | Off-Topic Lounge [WARNING: NO POLITICS] | 51 | 12-21-2012 03:46 PM |
| Speed cats (or other driving shoes) | Symbiont | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 06-14-2012 11:10 PM |
