Old 08-15-2014, 02:37 AM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Window rubber seal causing squeaking sound?
My car has 21k miles on it and I've owned it since Dec 2012. Recently I've been having a problem with a squeaking sound just as the window fully closes. At first I thought it was just dirty and caused extra friction causing the sound but after it never went away even when I tried cleaning it with alcohol pads and other APCs and even lubricated it with WD-40 I realized it wasn't going away. When you touch the rubber it is clear that it feels "stickier" on a certain part and doesn't seem like it will go away.
Basically as the window fully closes it catches the rubber and pulls it upwards and upon further inspection it look like the rubber has permanently deformed slightly. Has anyone encountered this kind of problem or know what I can do to fix it? Will the dealer fix this under warranty?
I have messed around with the rubber before (pulled it out and pushed it back in) which may or may not have caused it to start rubbing..
l0aded is offline   Reply With Quote
Old 08-15-2014, 06:18 AM   #2
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
It (deforming) happened to my driver side and I got it replaced under warranty.
http://www.ft86club.com/forums/showthread.php?p=1880648
But replacing the rubber piece didn't stop it from squeaking.
Sigh-on-Rice is offline   Reply With Quote
Old 08-15-2014, 01:59 PM   #3
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Yep. Mine's been doing this for a few months. No issue with the quality of the seal... but it's a minor annoyance.
I've also heard that it's warranty-able, but if there isn't a proper resolution with Subaru, it's a waste of time (to me).
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 08-15-2014, 02:16 PM   #4
extrashaky
Drives: 2014 BRZ Limited
It's a known issue. There are multiple fixes. The simplest one is to just use Armorall once a week on the seal.
A more complex fix is to adjust the window angle. There's a bolt in the door that adjusts the angle of the window so that it may not pinch. It involves taking the interior door panel off. Apparently some of the dealer mechanics have no idea how to do it, so you might have to find the thread on here where one of the members did it himself and took a picture.
If it were me, I would have the dealer replace the seals under warranty (to get rid of the pinched seal you have now) and then Armorall the replacement seals once per week thereafter to see if that fixes it. If not, then move to the window adjustment.
Old 08-15-2014, 03:08 PM   #5
l0aded
Addicted
l0aded's Avatar
Quality control fail. I'm glad it's a known issue at least and I can possibly have it replaced. I might try the armorall on both sides if they replace it to prevent it from occuring again.
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Weather strip/Rubber seal for bodykits FRSHunter Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 04:34 AM
squeaky window due to window rubbing against rubber at the top tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-10-2013 05:34 AM
Small window door issue (rubber seal) Subforever Issues | Warranty | Recalls / TSB 7 05-20-2013 05:32 AM
Squeaking or squealing window Cjm005 Scion FR-S / Toyota 86 GT86 General Forum 1 12-25-2012 12:19 AM
