Old 09-01-2014, 04:50 AM   #1
JohnAyySays
JohnAyySays's Avatar
Drives: Scion FR-S Whiteout
Rubber/Tire Sound after lowering springs
Hey Guys! So I've recently installed the eibach prokit springs on my frs and I've heard no clunking sounds over bumps/speed bumps. Recently going up my driveway I've started to hear a noise that sounds like rubber rubbing against each other. Before when I used to go up my driveway I had to fully turn my wheel to get up which caused my passenger rear wheel to lift up. Because I'm lowered would that cause the tire to make that noise? I only hear that noise on my passenger rear wheel. Thanks again!
JohnAyySays is offline   Reply With Quote
Old 09-01-2014, 09:11 AM   #2
Turdinator
Señor Member
Turdinator's Avatar
Did you get an alignment after you installed the new springs?
1974 TA22 Celica
2013 86 GT
Old 09-01-2014, 09:36 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
You say you hear rubbing? You don't say what wheel and tire sizes you have
How can we help?
If you hear rubbing... It's rubbing...
Old 09-01-2014, 11:51 AM   #4
JohnAyySays
@Turdinator not at the moment waiting on springs to settle @ZionsWrath stock tires and wheels sorry. Not sure if it's rubbing but it sounds like when you were to lift your car on jacks and you slowly lifting up the tire from the ground
Old 09-01-2014, 12:20 PM   #5
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Did you take the wheel/tire off the car to see if you could see any signs of rubbing, either on the tire itself or on the car?
Another way to check for tire rubbing is to mark the tire in question with tire chalk and then check to see if it's been smudged or disturbed in a way that would indicate rubbing.
dradernh is offline   Reply With Quote
Old 09-01-2014, 08:16 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
I would say without an alignment you have some extra toe and that is causing the noise.
1974 TA22 Celica
2013 86 GT
Rubber Plug For Sound Generator Tee Uniquedetail DIY (Do-It-Yourself) Guides 4 08-20-2014 10:10 PM
Window rubber seal causing squeaking sound? l0aded Issues | Warranty | Recalls / TSB 4 08-15-2014 03:08 PM
Rubber Tire Mark Cleaner ryuusei Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 05-27-2013 05:21 PM
Remove tire rubber off car paint (Opti coat applied) Nardi330 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 11-16-2012 11:18 PM
Rubber Plug for Sound Generator Tee Uniquedetail Engine, Exhaust, Transmission 3 10-10-2012 11:18 AM
