Drives: '13 black BRZ MT
No coolant light
I noticed I have no more coolant in my coolant container but why hasnt my low coolant light turned on? Is it normal for coolant to fully drain after 1.5 years of having the car? I only have 16k miles
Drives: white premium brz M/T
my coolant seems to disappear after few thousand miles too. i think it's normal on 86 bc i don't see/smell any leaks
Mine goes empty 5-10k miles
Drives: 2005 Toyota Camry
1) because your system is still full...
2) it does need to be replenished regularly (the overflow tank) [ame="https://www.youtube.com/watch?v=V7inC4lOpGs"]How Car Cooling System Works - YouTube[/ame] -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | number1Tango (09-23-2014) |
Drives: Asphalt Scion FR-S
There's no low coolant light. You'll just see your coolant temp gauge go really high or the ECU will throw a CEL for low voltage on coolant temp sensor if it's dangerously low. If not just top off with Subaru/Toyota OEM BLUE coolant or distilled water and should be good to go. Reason I know is I've had my engine nearly overheat twice due to a leaking radiator where it was dumping coolant.
My temp gauge has been looking normal. I wasnt aware this car doesnt have a low coolant light.
Drives: 2019 BMW ///M4
Did you also know there's no maintenance light? LOL
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
Drives: Firestorm 86
What kind of coolant be used?
I just notice the reserve tank is empty so i was planning on getting peak coolant |
Drives: JAWS
Can you not read 3 posts above yours?
Drives: Scion FR-S, Ultramarine
Just top it off with distilled water. It seems that the water is evaporating from the coolant reservoir, so the concentration of coolant remains the same. If you added more coolant it would just create a higher concentration
| low coolant | BRZPDX | Northwest | 17 | 06-06-2015 01:42 PM |
| FRS uses a lot of coolant? | JLMtm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 124 | 01-23-2015 06:34 AM |
| Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? | mike the snake | Forced Induction | 8 | 04-01-2014 05:56 PM |
| is my coolant low? | chenshuo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 12-19-2013 11:43 PM |
| Low Coolant | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 12 | 11-25-2012 12:03 PM |
