Old 11-20-2012, 08:55 AM   #1
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Low Coolant
So I went to go change my DRL's to LED's and I noticed my coolant level was below the low fill line when the car is cold. The car only has 9500 miles on it. Is this normal? Or should I take it to the dealer for a possible coolant leak?
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 11-20-2012, 09:42 AM   #2
Blue86
Drives: Sonic Blue 86GT Manual
odd. these cars aren't meant to need the cooling system serviced for some really long amount of time like 12 years or something.
let the dealer check it to be safe
Blue86 is offline   Reply With Quote
Old 11-20-2012, 10:15 AM   #3
whtchocla7e
Drives: 2013 FR-S Hot Lava
Are you looking at the reservoir tank?
Then it should be fine if it's below the low marker when the engine is stone cold.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 11-20-2012, 03:45 PM   #4
Don Ivey
Drives: '13 FR-S
Just buy some coolant (Scion brand) and add to correct mark. It's easy.
Don Ivey
'13 FR-S (Hot Lava)
Don Ivey is offline   Reply With Quote
Old 11-20-2012, 08:25 PM   #5
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
I had the same thing happen, around 9000 miles I noticed the coolant was low, I topped it off and it's holding steady (at 11,000 miles now.) I don't think all of the air was bled out of the system at the factory and I just didn't notice until now. I really hope it's not a leak.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 11-20-2012, 09:54 PM   #6
Craig
Craig's Avatar
Drives: Asphalt FRS
I noticed my coolant getting low (between full and low) the other day, @ around 3500 miles. Probably nothing to worry about, just gonna top it off if it gets low.
Craig is offline   Reply With Quote
Old 11-20-2012, 10:18 PM   #7
IllusiveFRS
IllusiveFRS's Avatar
Drives: 13 Scion FRS, Asphalt
That should be noted when you take it in for service. Let them know, my dealership topped it off for me at each service since I let them know. 13k and it is holding for now.
13 FRS Asphalt
Jackson Racing Supercharged, Nameless Performance front pipe with cat and helmholtz resonator, Greddy EVO3 exhaust, tuned by Church Auto Testing. Cusco braces all around, KW V3 coilovers. Winmax brake pads with DBA rotors. Thank you CSG for all the useful help!
IllusiveFRS is offline   Reply With Quote
Old 11-21-2012, 06:34 AM   #8
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
NEVER add more coolant to the cooling system. Always top up with de mineralised water
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 11-21-2012, 07:08 AM   #9
RoryTate
Not so in North America my friend. The appropriate antifreeze/water mix is required unless you don't drive in the winter.
RoryTate is offline   Reply With Quote
Old 11-21-2012, 09:37 AM   #10
Tt3Sheppard
Yea she's due for an oil change at 10500 so I should be hitting that sometime next week. I'll bring it in and have them check it out.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
Old 11-21-2012, 11:17 AM   #11
dsgerbc
Drives: BRZ(sold), STI
Not sure of the specs of the regular 'Scion brand' coolant, but if one uses it to top off the system, service/replacement frequency should be adjusted accordingly. OEM coolant is a long-life coolant with first replacement @11years/137kmiles. If all OEM Scion coolant is like that - do it.
If not - get a proper coolant.
Lol @'de mineralized water' comment.
dsgerbc is offline   Reply With Quote
Old 11-25-2012, 10:12 AM   #12
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
I don't care what the service freq is... I'm replacing my every 2 years... A proper flush and change. Call it overkill, but to maintain the life of the vehicle, its worth it to me. Just like they say you don't have to change the oil but every 7500 miles, which to me is full of shit too! 3k or 3mo.... thats what I have always done. Thats what I will continue to do!
ravenblackfrs is offline   Reply With Quote
Old 11-25-2012, 12:03 PM   #13
JohnS_Rosamond
Drives: Mazda MX5
Low coolant in the reservoir overflow bottle is not a biggie. I do not think that this constitutes a possible leak. As stated before, have your dealer make a note of it and have them top it off. For me, I think that I would be more concerned if the car was full hot and the reservoir was empty (or something like that). If this was a used car (and the amount of fluid missing from the reservoir bottle was small), I would top off with some distilled water. But as said, if the bottle was empty, then it's time to look for something else (like a bad radiator cap, or leaks).
JohnS_Rosamond is offline   Reply With Quote
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 08:15 AM
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 05:13 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 12:23 AM
