Old 01-15-2013, 04:25 PM   #1
JLMtm
Drives: FRS
FRS uses a lot of coolant?
Back when I got it in oct it was just under "full"
Now with 3k+ miles it's a little over "low"
Is this normal?
JLMtm is offline   Reply With Quote
Old 01-15-2013, 04:30 PM   #2
Wattage
Wattage's Avatar
Drives: scion fr-s MT
Are you checking at times when it is the same temperature? Hot fluid expands
Wattage is offline   Reply With Quote
The Following User Says Thank You to Wattage For This Useful Post:
Xovit (07-01-2016)
Old 01-15-2013, 04:33 PM   #3
ahausheer
Re-member
Drives: Toyota camry
Coolant expands as it warms up and contracts as it cools, so you need to specify when each measurement was taken. Also, make sure the car is level. If you actually are loosing coolant that is not normal or a good thing. There is another thread asking essentially the same question, you may try to search for that. If you are truly loosing coolant there are only three possibilities. Its dripping/leaking due to a loose hose or connection (not to bad), its boiling-over and literally overflowing from the reservoir (not good, could be worse), or it is getting into the combustion chamber and being expelled in the exhaust (very bad).
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 01-15-2013, 05:49 PM   #4
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I noticed this as well a few months back. I brought it to the dealer for an oil change and they didn't mention anything. Although at the same time I forgot to mention it to them.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 01-15-2013, 05:56 PM   #5
wbradley
Sarcastic SOB
wbradley's Avatar
Mine is just at the low mark when cold. However the car is garaged for the winter and there is probably 2-3 degrees incline in the garage so I might actually be slightly above the line in reality. If its boiling off you'd have an engine temp warning normally.
Just tell the dealer next oil change. You don't want to mess with doing your own dilution on this super duper lifetime coolant.
Old 01-15-2013, 10:10 PM   #6
pkny
Drives: Firestorm FR-S 6MT
Same thing here. Bought the car in May, and the coolant was sitting at the high mark. Now the coolant is at the low mark. I did both measurments first thing in the morning. I think the ambient temperture plays a important factor here. Back in May the temperture was 80 degrees, and now it is 40 degrees. Anyway, I checked with the dealer last week, and they just wanted to add some coolant. But the only coolant they have is the Toyota pink coolant, and they are not going to order the blue one. Screw that dealer. I went to a Surbaru dealer today, and bought myself a Surbaru blue super coolant. I will add the coolant tonight, and keep an eye on the level.
2013 Scion Firestorm FR-S MT
pkny is offline   Reply With Quote
Old 01-15-2013, 10:16 PM   #7
Hardrock4445
Hardrock4445's Avatar
May still have burped some air from factory. I would keep an eye on the level and not let it worry you unles it starts losing more.
Hardrock4445 is offline   Reply With Quote
Old 01-15-2013, 10:22 PM   #8
Celica00
Celica00's Avatar
Drives: 86
i wish it was 40 degrees here. you lucky bastard
Celica00 is offline   Reply With Quote
Old 01-15-2013, 11:12 PM   #9
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
The coolant level should be stable. Short of clearing a big bubble it should not change if checked under the same circumstances. You might peek down towards the drivers side of the crank pulley at the water pump. If you have a leak, you will see crusty blue buildup.
Mine had some there from the factory but I talked to a friend in engineering and heard that it could be normal from the initial install at the factory, so I cleaned it off and have watched it closely and no more has showed up since. My level has been rock solid.
Boosted2.0 is offline   Reply With Quote
The Following 3 Users Say Thank You to Boosted2.0 For This Useful Post:
b1pkkf26 (01-16-2013), FRSupra (01-16-2013), tripjammer (02-22-2013)
Old 01-16-2013, 12:20 AM   #10
whataboutbob
AutoX-10/10ths every run
I've noticed that mine has been low on a couple of occasions. Prob have added 16 ounces or so. Not sure if when it went in for the free scheduled maintenance if they added any. No sign of leaks or overflow either.
Build thread:Here
Old 01-16-2013, 01:52 AM   #11
Zach
Drives: 13 FR-S Black MT
13k miles here - was just on a 700 mile road trip when I noticed a funny smell at a motel when i stopped for the night. Checked it in the AM and the coolant res was BONE DRY. No idea how much was in the rad but i didnt have any CEL or warning lights and had not checked since my last oil change so no idea how long its been dry.
I found a toy dealership close to me and got to spend the entire day there, the end result was a ok pressure test and them filling it back up. Not happy, keeping my eye on it.
Zach
Zach is offline   Reply With Quote
Old 01-16-2013, 02:13 AM   #12
EK_Golfer
EK_Golfer's Avatar
Drives: 2013 Whiteout FR-S AT
From the dealership, my coolant was a bit above the full line. Now 400 miles in, it's almost an inch below it. I'm guessing it's just the colder weather
EK_Golfer is offline   Reply With Quote
Old 01-16-2013, 02:43 AM   #13
_hollywood
Drives: 97 itr sold
Hmmm i had low coolant at around 10k, im at 13k but havent checked it....too damn cold out....i hope this is nothing major
FR-S #56 of 86 Raven MT ***FOR SALE***
_hollywood is offline   Reply With Quote
Old 02-09-2013, 04:02 PM   #14
rasec29
rasec29's Avatar
Drives: '09 xB & '13 FR-S
At dealer now doing 15k mile service and they told me coolant is really low. I had to buy a gallon for them to add, $44... They couldn't tell me why it was low. I thought they topped off fluids at service. :confused:
Sent via Galaxy Nexus
rasec29 is offline   Reply With Quote
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 09:15 AM
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 06:13 PM
Coolant Levels DriftEightSix AUSTRALIA 17 01-29-2013 10:19 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 01:23 AM
