Northwest AK, ID, OR, WA
Old 01-03-2014, 07:14 PM   #1
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
low coolant
Anyone having issues with low coolant levels? I popped it off this summer but its low again. I suggest everyone to take a peak. so many theories going around, but would b nice if someone has a real answer to this issue.
Mine is 1/4 in below the low line in the reservoir tank after diving for 20min. will check when engine is cold.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 01-03-2014, 07:28 PM   #2
ramiram1984
Drives: 2016 STi DGM
Lol
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 01-03-2014, 08:01 PM   #3
PoWn3d_0704
PoWn3d_0704's Avatar
Drives: 1990 BNR32 GTR
If there is coolant in the bottle every time you check you're fine. The bottle is just a reservoir. Nothing more. It isn't even needed if your coolant level is perfect, in theory. The bottle is there so it CAN be a 1/4in low.
Hence the 'Lol' in @ramiram1984 post. I figured I'd be a little nicer.
Picked up my BRZ on 6/11/13.
Build Album:
PoWn3d's BRZ Pictures
Build Thread: PoWn3d's BRZ
PoWn3d_0704 is offline   Reply With Quote
Old 01-03-2014, 09:46 PM   #4
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Mine looses coolant slowly as well, I'm pretty sure it is just due to the water in the mixture gradually evaporating out with how hot our cars tend to run. I've looked pretty closely at mine and do not see evidence of coolant leaking anywhere.
Decay107 is offline   Reply With Quote
Old 01-03-2014, 09:55 PM   #5
humfrz
Yep, check it cold and report back ....
If it is below the "low" mark, and it makes you feel better, you could bring it up to above the low mark by adding the blue Toyota/Subaru coolant or, since you're in Oregon, a bit of distilled water.
humfrz
Old 01-03-2014, 10:02 PM   #6
ramiram1984
I didn't mean to be rude or make it sound like that. Honestly, it's bc I wondered the same thing when I 1st purchased my vehicle last march
-2014 SSM BRZ MT
Old 01-04-2014, 12:06 AM   #7
BRZPDX
Boosted Member
BRZPDX's Avatar
Just checked after the engine cooled. Coolant reservoir is completely empty now. I will add 50/50 coolant tomorrow so it will be inbetween full/low line. This will be the 2nd time filling up the coolant with a total of 18k mile on the odometer.
There seems to be numerous members on this forum that has similar issues, FI or N/A, bone stock etc.
I'd check your coolant levels.
Old 01-04-2014, 12:22 AM   #8
humfrz
Yep, if the coolant is not showing up in the tank, I'd add some also. Be sure what you add is the "right stuff" .... the blue stuff doesn't get along with just any old anti-freeze.
I check mine from time to time and it pretty well stays about an inch above the low mark (when cold).
Ain't automobile ownership fun .....
humfrz
Old 01-04-2014, 01:07 AM   #9
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Cuz turbo.
Chen is offline   Reply With Quote
Old 01-04-2014, 02:48 AM   #10
Touge_ninja
Sending rods to their doo
Touge_ninja's Avatar
Drives: 700HP STi
No problem with my coolant levels.
Touge_ninja is offline   Reply With Quote
Old 01-04-2014, 05:29 PM   #11
BRZPDX
Boosted Member
BRZPDX's Avatar
I don't smell the coolant leakage nor visible evidence, but it does seem to get low pretty quickly compared to other cars I have owned. Today I was able to get the factory coolant from the dealership, and they recommended using the "super blue" instead of a universal 50/50 coolant from an autoparts store.
Upon doing more research, there are multiple theories on this forum:
Water evaporating since our engines run hot, and the reservoir cap is not air-tight.
Head gasket leakage
Radiator leakage
White smoke from exhaust after shutting car off indicates a possible radiator fluid leak, possible pump failure
low pressure cylinder head causing a leak (not exactly sure how this affects coolant)
The last 4 situation sounds a bit scary, while I was reading the 10 page coolant issue on this forum. I really hope its situation #1.
Old 01-04-2014, 05:36 PM   #12
Touge_ninja
Drives: 700HP STi
Head gasket leakage
Radiator leakage
Did you have this issue before you went turbo? i've been DD my car and have not coolant issues whatsoever.
Old 01-04-2014, 05:54 PM   #13
Decay107
Decay107's Avatar
Well if it makes you feel any better, I'd say its unlikely a head gasket issue. Mine looses some coolant, so I sent used oil in to blackstone for analysis. It came back with no coolant or water in the oil.
Old 01-04-2014, 06:02 PM   #14
BRZPDX
Boosted Member
BRZPDX's Avatar
Yea my coolant was going quick before turbo. Although my car has been through about 8 Auto-X events, a road trip to Vegas in 115F desert heat, a few late night drift sessions, and a few passes at the drag strip.
Now that I have a good reservoir fill, it will be interesting to see if the turbo makes any difference.
When I fill the coolant, its always like such a short pour though. So not much is lost perhaps, just looks scary when its below the "low" or the reservoir is bone dry!
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 06:34 AM
is my coolant low? chenshuo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-19-2013 11:43 PM
Where did my coolant go? ZionsWrath Scion FR-S / Toyota 86 GT86 General Forum 1 11-02-2013 11:46 AM
Adding Coolant JLMtm Scion FR-S / Toyota 86 GT86 General Forum 5 05-11-2013 07:03 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
