Old 12-19-2013, 09:42 PM   #1
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
is my coolant low?
When checking cold, my coolant is 1 inch above the Low mark. Do i need to top it up more? I don't have any coolant laying around and i don't know which coolant i need to use for the BRZ. How much would it cost to buy at the dealer?
Edit: oops i meant to say the min mark of the OVERFLOW container, not the radiator. My coolant is about an inch above the min mark of the plastic overflow container.
chenshuo is offline   Reply With Quote
Old 12-19-2013, 11:18 PM   #2
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
No you're fine and dealership coolant doesen't contain fairy dust or unicorns. Canadian Tire stores etc coolant all equally as good in that respect.
Old 12-19-2013, 11:37 PM   #3
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Yes it does! Every molecule has a "SUBARU" stamp on them!
On a more serious note; it's because our season is changing and it's getting colder... However once you drive the car and you'll be surprised when you look under the hood, it will likely go back over the "Min" line as heat and pressure will expand the coolant.
As long as it is still above "Min" line when the car is in operating temperature, you're fine. Though adding a little more wouldn't hurt... And remember, that tank is a reservoir tank A.K.A overflow tank, most of the coolant is already in the engine/hoses, this tank is just to accommodate excess coolant when it expands and overflow.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 12-19-2013, 11:43 PM   #4
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Don't buy the green coolant. Go to Subaru and buy their super duper blue coolant costs ~$20 bucks but should last a long time. You don't want to be mixing colours as they are different albeit very minimally (additives and such).
Gords_zenith is offline   Reply With Quote
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 06:34 AM
Where did my coolant go? ZionsWrath Scion FR-S / Toyota 86 GT86 General Forum 1 11-02-2013 11:46 AM
Adding Coolant JLMtm Scion FR-S / Toyota 86 GT86 General Forum 5 05-11-2013 07:03 AM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 07:50 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
