Old 07-01-2014, 04:02 PM   #1
roybotnik
Drives: 2014 BRZ
Auto or Manual for FI?
I've always been a manual guy but... I'm getting rid of my 6mt 997 turbo and planning to get a BRZ. I'm sure I won't be very happy with the power for long so I think a turbo will be in my future. I'm curious about how good the clutch options are for FI applications (I dunno, 300ft/lbs tq?).
Does the auto withstand decent power gains at all? After having a modded 2011 Mustang GT w/ all sorts of clutch shittiness and replacing the clutch in my 997TT to the tune of $3500 only to end up with a jumpy car, I'm wondering if an AT might be better for increased HP applications...
roybotnik is offline   Reply With Quote
Old 07-01-2014, 04:51 PM   #2
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
It's proven and confirmed by Tada himself that stock vs. stock the AT holds higher torque than MT. However, I doubt it's designed to hold twice as much torque vs. stock w/o any issues at all.
Efferalgan is offline   Reply With Quote
Old 07-01-2014, 04:57 PM   #3
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
For a small fee (uh think like 1500ish?) you can upgrade the valve bodies and torque converter on the AT with the addition of a tranny cooler, aiding in the longevity of the unit itself. I was told by @Jason@DSG that it would 400-450 whp (assuming 320-370 wtq) fine.
Old 07-02-2014, 12:23 PM   #4
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
Typically the transmission itself is pretty robust and SSP is currently finishing up testing on the clutches. The AT's are going to be a force to be reckoned with.
I'm just waiting to hear back from SSP with the final testing results before I make any number claims.
Jason@DSG is offline   Reply With Quote
The Following 2 Users Say Thank You to Jason@DSG For This Useful Post:
JonAvalon (07-02-2014), Knickstape (07-03-2014)
Old 07-02-2014, 12:31 PM   #5
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
seems stock manual transmissions explode around 400wtq(which depending on turbo is over 500whp), alot less if you actually have traction. Clutches arnt a problem, I have an act streetlite at 380wtq no issues (but I have no traction) and exedy makes some pretty awesome clutches as well. They also make the oem clutch which is good for around 300ish. You could always swap in the v160 from fullblown and that will hold over 1000whp
Old 07-02-2014, 12:31 PM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
What are your goals? Straight line or track? If you want to go fast in a straight line, I suggest another car. If you want to go fast on the track, the manual probably provides more potential. If you want more engagement with driving, get the manual. If you face traffic, the auto is better. If you want really insane power, you'll probably have to replace either one with something beefier. I've not seen many complaints about the manual, and I have seen plenty of positive things said about the auto, but I think the car really is manual-focused.
Old 07-02-2014, 01:56 PM   #7
roybotnik
Drives: 2014 BRZ
Yeah totally agreed. I am coming from a tuned 911 turbo and I'm not really interested in the straight line anymore...been there done that. I'm not looking for insane power, just something that will get rid of the torque dip and make it a little easier to live with. VA is full of aggressive assholes and having no torque makes it hard to avoid them when they do something stupid.
If there's decent clutch options then I'll probably stick with the MT. The shifter blew my mind when I took one for a test drive. I'll probably check out an auto though, just to be sure..
Old 07-02-2014, 02:49 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You won't like the auto. Get the manual.
Old 07-02-2014, 03:11 PM   #9
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
it's a very good question IMHO, since there are pros and cons with both options ....even though I have a manual with SC, I feel that a really good auto might be even better for track use especially with the FI..
Many people think that the manual is better suited for track use and auto is better for street use, it's quite the opposite if you take everything into consideration,.. manual is one for twisty backroads and the three pedal feel is nice but it will definitely cost you when it comes to lap times
Most of the time people neglect the fact that good autos shifts a lot faster and more accurately than any human, I didn't get a chance to drive an auto with paddle shifters in FRS or BRZ but people seem to like it.. with FI, it would be easier to maintain the car in power band and definitely help for rev matching(blipping the throttle) ,,let's take a look at the GT-R, without the robotic manual the car would never be able to upshift and keep the boost steady..
in addition, it is a lot easier to use left foot brake (for those who want to utilize trail braking) ..
so there are always compromises in each scenario and manual transmission is not always the best option for all the time..
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
Silent_Dan (07-02-2014)
Old 07-02-2014, 03:26 PM   #10
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I just wish the 6th gear wasn't so f'n long in the auto
Old 07-02-2014, 03:51 PM   #11
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I wish 6th gear in the manual was as long or longer than the auto's 6th gear as I'd prefer to get 2k rpm when on the freeway instead of 3k+.
Manual trans = more fun, work, time spent changing gears, holds less power.
Auto trans = less fun, less work, less time spent changing gears, holds more power.
Thus if the same power is getting to the wheels, the auto will be faster and a better daily driver. I go with manual as I fall asleep when driving an auto as I get bored.
If you go over 300whp you'll need clutch, injectors, fuel pump, basically a lot of stuff. Stay around 250whp and you won't need anything but the supercharger or turbo kit. This is one reason why I have the Innovate kit, that and I got it used for super cheap.
stockysnail is offline   Reply With Quote
Old 07-02-2014, 04:02 PM   #12
CSG David
CSG David's Avatar
AT or MT doesn't matter. Your interest in either platform requires dedicated builds and goals. Either has its perks and either one will be built differently. Balance and reliability is the systematic integration of all the components working in perfect harmony on the car. We have a certain lust over the AT setup simply due to the insane traffic we have in California, but we have also developed potent MT setups that seem to be reigning at the podium for track driving and daily comfort.
Old 07-02-2014, 04:30 PM   #13
EAGLE5
Dismember
EAGLE5's Avatar
For me, this car is all about fun through involvement while being cheap enough that I feel I can push it. A manual is more fun because of the involvement. With a good automatic, a novice like me has less to worry about on the track and can often go faster. Still, I found that, with my BMW, it was hard to power out of turns because the auto was too slow on the downshift. I don't know what the FR-S auto is like. Like I said, I hear good things.
If you want to cut the torque dip, I'd get a header and tune, and maybe the Crawford Power Blocks. A tune alone is great. An e85 tune alone is greater. A header is even more awesome. I haven't tried the Power Blocks, but I only hear good things, and the dyno curves look fantastic. You'll still have to downshift, though, if you want torque.
Old 07-02-2014, 04:46 PM   #14
jflogerzi
jflogerzi's Avatar
If you have read the power blocks are worthless on e85 tune
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Auto to manual ric342 Scion FR-S / Toyota 86 GT86 General Forum 135 04-10-2013 11:43 PM
Auto to Manual Obja Scion FR-S / Toyota 86 GT86 General Forum 14 02-04-2013 11:45 AM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 11:33 AM
Manual or Auto? StevenDavisPhoto Engine, Exhaust, Transmission 23 03-30-2012 05:58 AM
