CANADA Canada
Old 02-23-2013, 09:14 AM   #1
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Brake rotor differences between base and Sport-tech BRZ
There was an off-topic discussion in this thread about whether or not there are any differences in the brake rotors between the base and Sport-tech BRZ models.
I called the parts desk at a Subie dealer this morning to see if the part numbers are identical for the brake rotors on the base and Sport-tech models. The parts manager said he did not have the February update yet, but according to his database, the front rotors are common to both, but the rear ones have different part numbers. He could not give me the rotor dimensions so we still don't know what the differences are though. (According to the Canadian BRZ options sheet PDF from April, the Sport-tech rotors are thicker but not bigger.)
Sport-Tech is offline   Reply With Quote
Old 02-23-2013, 12:21 PM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
Hmm... Interesting. Let us know what you find out. It could turn out to be a cheap and easy upgrade for the FR-S.
Old 02-23-2013, 02:03 PM   #3
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
I've got an email in to customer relations, hoping to hear back after the show is over.
Old 02-24-2013, 12:36 PM   #4
wbradley
Sarcastic SOB
wbradley's Avatar
Why worry, rotors are wearing parts that are usually just replaced these days. You would do better in terms of value buying non-OEM rotors if you want better braking.
On the Scion I do recall noticing both the rear and front rotors were vented which is not typical for the price point.
FYI- according to Subaru Canada website specs, the diameter and thickness of the rear rotors are identical in both models.
Old 02-24-2013, 12:52 PM   #5
Future
Future's Avatar
Drives: BRZ!
If you want to order aftermarket rotors... You have to know the size you have to order..
Many will likely say the FR-S/BRZ needs more power and while more wouldn’t hurt, those folks (the same ones who have probably never driven on a track) are missing the point.
Future is offline   Reply With Quote
Old 02-24-2013, 05:40 PM   #6
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
As mentioned in the other thread, I was explicitly told by an HQ staffer that the website information was wrong.
Old 02-24-2013, 05:52 PM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
Burrcold just measured his sport tech and his rotors are same thickness as my FR-S. See CIAS thread under Canada.
The Following User Says Thank You to wbradley For This Useful Post:
Burrcold (02-24-2013)
Old 02-25-2013, 09:42 AM   #8
wparsons
wparsons's Avatar
As I said in the other thread, there are no models sold anywhere that come with 40mm thick rotors stock.
The only different brakes are the Australian GT (base) model, which has smaller diameter fronts and non vented rears.
If you look at the WRX front brakes (which these cars use), there's no 40mm thick rotors either. A 40mm thick rotor is 1.5" thick, which is massively thick.
Anyone here have a base BRZ to measure the rotors on? The smaller rotors (Ausi GT) are like 272mm IIRC, the exact dimensions are in the other thread.
flickr
Old 02-25-2013, 12:07 PM   #9
engsr
Drives: Subaru BRZ
Aside from physically measuring the rotors, compare the part numbers of the calipers and pads. If they're the same, then the rotor has to be the same, dimensionally. If not, then who knows what the difference is - my guess would be the hub offset. But it seems unlikely the rotors are different.
And to be honest, the rear brakes do maybe 25% of the total braking, so I wouldn't be too worried about it. Besides, I highly doubt anyone will notice the difference anyway if the rotors were different for whatever reason.
Bryan.
engsr is offline   Reply With Quote
Old 04-11-2013, 11:34 PM   #10
troek
troek's Avatar
Drives: 2012 Toyota 86
in japan base model brz/86 have non ventilated rear roters as well. if thats the only difference i wouldnt worry at all.
Old 04-12-2013, 07:15 AM   #11
Burrcold
Drives: Subaru BRZ Limited
There is no difference here.
FS: BRZ Sport Tech in Edmonton tawheed Canada Classifieds 1 03-10-2013 06:17 PM
Black BRZ Sport tech for sale Dandy care CANADA 14 02-14-2013 09:52 AM
SWP BRZ SPORT TECH MANUAL FOR SALE Skye CANADA 2 11-14-2012 08:27 PM
Hello =D, WRB MT BRZ Sport Tech (markham ontario) funcheung CANADA 5 07-08-2012 08:04 PM
BRZ Limited vs. Sport-tech - the differences Sport-Tech CANADA 49 05-24-2012 07:33 PM
