Old 06-28-2014, 04:35 PM   #1
fstlane
fstlane's Avatar
Drives: BRZ Limited
Seized brake rotor removal tool
While replacing my wheel studs I discovered my rotors were stuck and I didn't have the correct size bolts on hand to remove them. I found the spare tire hold down bolt is the correct size and makes the perfect tool for the job!
fstlane is offline   Reply With Quote
The Following 19 Users Say Thank You to fstlane For This Useful Post:
azian_advanced (07-20-2014), Black Tire (07-20-2014), Deep Six (07-21-2014), dirtbike250x (09-10-2015), finch1750 (07-20-2014), Jrryjms07 (09-06-2015), Lav (08-09-2020), lightdir (09-11-2015), Lorico (03-26-2015), Nm86 (06-29-2014), Pat (03-15-2015), roddy (07-21-2014), Slowbro (07-27-2023), Sony (07-21-2014), Thorpedo (09-24-2015), willypongtb (06-30-2014), XtremeMaC (04-28-2019), zc06_kisstherain (07-21-2014), zoth (04-25-2015)
Old 06-28-2014, 04:37 PM   #2
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
nice "life hack" or whatever the kids call it these days. I like when odd things work out like this.
The Following User Says Thank You to Reaper For This Useful Post:
fstlane (06-28-2014)
Old 06-28-2014, 05:01 PM   #3
White64Goat
Did you have the emergency brake on by chance?
Old 06-28-2014, 05:01 PM   #4
Reaper
Reaper's Avatar
Drives: violent
I was thinking the same thing, ha.
Old 06-28-2014, 05:24 PM   #5
fstlane
fstlane's Avatar
Drives: BRZ Limited
No, there was just rust built up at the rotor to hub seating surface.
The Following User Says Thank You to fstlane For This Useful Post:
Old 06-28-2014, 05:30 PM   #6
White64Goat
Old 07-20-2014, 10:48 AM   #7
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Savior
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
The Following User Says Thank You to Tt3Sheppard For This Useful Post:
fstlane (07-20-2014)
Old 07-20-2014, 03:03 PM   #8
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
Nice find!
When I did the brembo brake conversion, I had to take my bike to the parts store to get a couple of M8 x 1.25 bolts.. if only I had known about this back then.
Not sure if coincidence, or the engineers designed the spare tire tie-down bolt specifically with this in mind.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
The Following User Says Thank You to azian_advanced For This Useful Post:
Old 07-20-2014, 04:20 PM   #9
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Nice find !
B-R-Z is offline   Reply With Quote
The Following User Says Thank You to B-R-Z For This Useful Post:
Old 07-20-2014, 11:08 PM   #10
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Did you try hitting the flat part of the rotor hat with a big hammer first?
Nice find, I may end up using this one day!
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
The Following User Says Thank You to Black Tire For This Useful Post:
fstlane (07-21-2014)
Old 07-21-2014, 01:10 AM   #11
fstlane
fstlane's Avatar
Drives: BRZ Limited
No, I tried a few light blows with a rubber mallet on the backside rotor face with no results. I then tried the tire bolt and both rotors pressed off easily with just a few turns of the handle.
Old 07-21-2014, 09:24 PM   #12
roddy
roddy's Avatar
Drives: '13 Ultramarine
Nice find! I keep a couple of metric bolts in the "tune-up" drawer just for that reason, but for those who don't, this is a good tip. Thanks for posting it up.
The Following User Says Thank You to roddy For This Useful Post:
Old 09-05-2015, 11:09 PM   #13
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I tried this earlier today for the rear rotors, it worked but it fucked up the threads real nice. I suppose on Monday I'll be ordering a new one...
It's my fault and I'm by no means blaming the OP. I highly recommend grabbing a bolt from the front undertray instead, it's far stronger
Old 09-06-2015, 12:45 AM   #14
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I think it's designed this way lol. Did you know the screw driver in the trunk alone is all you need to take apart all interior? LoL
I noticed this when I was doing sound deadening and install OEM+ for my car.
DIY: Front Brake Pad and Brake Rotor Replacement F1point4 DIY (Do-It-Yourself) Guides 28 03-21-2021 10:22 PM
e-brake removal, spacer to remove backplate puma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-31-2014 07:48 PM
R1 Concepts rotor, and brake pads ExtremeAutowerks Brakes, Suspension, Chassis 37 12-23-2013 03:39 PM
Radio removal tool brzing Electronics | Audio | NAV | Infotainment 1 07-13-2013 06:56 PM
Brake rotor differences between base and Sport-tech BRZ Sport-Tech CANADA 10 04-12-2013 08:15 AM
