Old 10-17-2013, 07:55 PM   #1
jamesm
MTEC shifter spring install issue
I received the MTEC shifter spring kit recently and decided to have a crack at installing it today. i was able to get the first spring in pretty easily (the one behind the 10mm hex bolt), but the detent won't come out for anything. torque rating is 29ft/lb, and i couldn't get it off with a breaker. i was actually afraid to break it and quit as the sun was going down. i'll try again in the daylight tomorrow.
did anyone else have issues getting that out? i fear mine may have been cross-threaded on at the factory or something.
Old 10-17-2013, 08:53 PM   #2
Dipstik-sportech
Dipstik-sportech's Avatar
Gotta love locktite. It will come loose it's just a bitch
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
jamesm (10-17-2013)
Old 10-18-2013, 07:17 PM   #3
jamesm
finally got it out of there, it was pretty rough but totally worth it. the shifter feels amazing now. definitely the best mod i've done for the price ($30 or so).
The Following User Says Thank You to jamesm For This Useful Post:
Anthony (10-20-2013)
Old 10-18-2013, 07:18 PM   #4
OrbitalEllipses
Drives: Attitude
Describe the differences qualitatively please.
MaXimus (02-10-2014)
Old 10-18-2013, 07:23 PM   #5
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
i might pick up a set of these springs soon as well. @jamesm do you have any other transmission bushings/inserts installed? i was thinking maybe the springs and a kartboy transmission mount insert
abutterman is offline   Reply With Quote
Old 10-18-2013, 10:31 PM   #6
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
It feels like it allows the shifter to return to neutral zone faster and more precisely without much user input. So shifts from 2nd to 3rd are easier, along with 4th to 5th, and for the reverse order. I've always found myself not shifting fast enough from 4th to 5th especially with flat foot shifting, but these springs help out immensely. Smooth! I hope that was a qualitative enough explanation. But if someone your neighborhood or area has one of these installed, you can test it out. If I was there, I'd let you test it out.
As for quantitative, I think MTEC has a video on their website that describes how the spring tension does something something something to the shifter. lol.
Hope this all helps.
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
The Following 3 Users Say Thank You to markmatley For This Useful Post:
Enraged21 (10-20-2013), EvilBeaverFace (10-19-2013), jamesm (10-19-2013)
Old 10-19-2013, 04:14 PM   #7
jamesm
@markmatley has it pretty much spot-on. i'll just add that it feels much, much tighter as well, in that there is a lot less slop in the shifter. it also made actually going into gear much smoother and more like a 'click' than a 'crunch'.
i actually didn't expect these springs to do much for $30, i just did them because they were cheap and i was doing a fluid change. the difference is pretty shocking.
Fizz (10-20-2013)
Old 10-19-2013, 06:58 PM   #8
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I can echo this being one of my favorite cheap mods as well. It's been pretty well described for sure just feels tighter and more direct.
Old 10-19-2013, 07:45 PM   #9
OrbitalEllipses
Drives: Attitude
Thanks. I'd seen the install video on the MTEC site, but wanted to know what it felt like.
Old 10-20-2013, 12:40 AM   #10
zooki
Drives: waiting on a 2021...
I wonder how these would work with a Kartboy
shifter? Anybody combine the two?
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 10-20-2013, 05:16 AM   #11
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm installing this next week....relatively cheap mod so I figured what the heck I'll give it a try.
Fizz is offline   Reply With Quote
Old 10-20-2013, 05:39 AM   #12
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I've got the Kartboy shifter, MTEC springs, and Whiteline "positive shift kit" all sitting in boxes at home, waiting for me to install next month. I'm going to do them all at once, so I won't be able to describe the difference of each one, but I expect it to be a night and day difference with all that.
Although I may hold off on the Whiteline part. I've heard talk about it being potentially harmful on your motor mounts and stuff if you don't replace all that type of stuff at once.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 10-20-2013, 11:48 AM   #13
jamesm
i don't have the kartboy shifter, i almost bought it but decided o see how just the springs and fluid would make it feel. i would imagine that both would be awesome.
Old 10-21-2013, 07:01 AM   #14
vgi
Drives: frs
What fluid did you go with?
vgi is offline   Reply With Quote
>>>FT-86 SpeedFactory<<< Kartboy Short Throw Shifter Kits and MTEC Springs FT-86 SpeedFactory Transmission and Driveline 267 12-11-2016 09:20 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
shifter issue? abutterman Issues | Warranty | Recalls / TSB 54 02-26-2014 05:10 PM
Need help fast - suspension issue during spring install finch1750 Scion FR-S / Toyota 86 GT86 General Forum 5 07-08-2013 03:30 PM
MTec Industries Shifter Springs xravexboix Transmission and Driveline 2 04-24-2013 12:39 PM
