Old 09-25-2013, 11:10 PM   #1
anewprelusion
Rear Camber/Alignment Question
I'm totally noob when it comes to Suspension/Camber/Alignment.
So my friend told me after looking at my car for maybe 5 minutes that my brand new BRZ needs alignment. He said my driver side rear wheel has negative camber and my passenger side rear wheel has positive camber. Sounds crazy right!?!?! Anyways, is there any truth behind this? I "thought" I might have seen the same thing as him, but it could just be the power of suggestion?
Can anyone chime in on this statement? Fact or fiction? Unless it came that way from the factory, I don't think I drove it hard enough to damage the suspension. Less that 200 miles on it. Either way I'm going to get it checked out by my friend the shop owner. Just wanted to see what others thought. Thanks!
anewprelusion is offline   Reply With Quote
Old 09-25-2013, 11:39 PM   #2
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
take a square piece of cardboard or something else and hold it against the wheels on a flat surface for a quick and dirty check. see what the difference is between the left and right. the cardboard should be tall enough to span the entire rim. for stock wheels, you'll be looking at the tire as it sticks out further than the rim. i know that there was a difference between the left and right rear camber on my BRZ straight from the factory.
shiumai is offline   Reply With Quote
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
toe, camber, castor? basic alignment question? rainmonkey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 05-18-2013 01:38 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
