Old 05-02-2014, 03:24 PM   #1
protpibe
protpibe's Avatar
Quiet sway bars
Can anyone recommend a front and rear sway bar combo that is SILENT?
I rolled the dice on a set of Hotchkis sway bars and they clunk like crazy. It's both the front and rear, and I've tried a few different endlinks. Tightening the links quietens them down a bit, but not for long. They usually stay quiet for a couple of days then go back to making noise. I've tried loctite and lock washers, but they keep backing off a very slight amount. I'm thinking the bolt holes on the bars themselves are slightly larger than the endlink bolt diameter.
Anyways, can anyone recommend a front and rear sway bar set that is dead silent? I just can't take the clickiing/clunk noises anymore.
I'm thinking Perrin
Old 05-02-2014, 03:27 PM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
a swaybar by itself cannot clunk, it has no moving parts
if it is clunking, there is metal on metal contact due to binding and improper articulation
The Following 3 Users Say Thank You to 7thgear For This Useful Post:
2013GTRNate (02-28-2016), Calum (02-27-2016), fatoni (05-02-2014)
Old 05-02-2014, 03:29 PM   #3
Racecomp Engineering
Are your bushings nice and lubed up? Wrapping the bar in teflon tape at the bushings helps as well.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Scooby South (05-02-2014)
Old 05-02-2014, 07:15 PM   #4
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
I run Hotchkis in front and no noise for me. What is your drop?
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 05-02-2014, 07:26 PM   #5
protpibe
protpibe's Avatar
About 1.5"
Are you using OEM end links?
Old 05-02-2014, 07:34 PM   #6
Gunman
Drives: 2019 Mazda Miata RF
I'm going to be installing a set of Hotckis bars tomorrow, I'm curious what's making the noise.
Gunman is offline   Reply With Quote
Old 05-02-2014, 07:45 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Always tighten bolts (especially on sway bars) with the wheels on the ground. You'll have to elevate the car using blocks of wood or ramps, but it's a must.
Otherwise, you're just binding/preloading the links and they'll always become "loose" after you start driving the car.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
finch1750 (02-29-2016)
Old 05-02-2014, 07:45 PM   #8
colHolm
Default User Title
colHolm's Avatar
check the torque on your top nuts.
colHolm is offline   Reply With Quote
Old 05-02-2014, 07:51 PM   #9
Mikepage
Mikepage's Avatar
About 1.5"
0.8" on the front and oem link yes.
o= FR-S =o
Old 05-02-2014, 08:14 PM   #10
protpibe
protpibe's Avatar
The top hats on the coilovers?
Sent from my HTC One using Tapatalk
Old 05-02-2014, 09:21 PM   #11
colHolm
Default User Title
colHolm's Avatar
Yeah, over the winter mine had backed off about a quarter turn, and I was getting a lot of clunking. Tightened them up, and now the suspension is quiet.
Old 05-02-2014, 10:18 PM   #12
wparsons
wparsons's Avatar
Are you sure you aren't getting any knocking from the swaybar to lower control arms? At a 1.5" drop and stock end links I would bet that's a strong possibility.
flickr
Old 05-02-2014, 10:23 PM   #13
colHolm
Default User Title
colHolm's Avatar
That was my thought when I was hearing the clunking, I am lowered about 1.5 with oe endlinks too. No contact, just slightly loose top nuts. It is easier to check them first.
Old 05-02-2014, 10:29 PM   #14
protpibe
protpibe's Avatar
The stock end links are too long. I went to whitelines , same knock. Got the oems shortened 50mm, same knock
It's fine at first but then the bolts back off a bit and it comes back. I'm pretty sure the bolt hole on the bar is slightly too large and it moves around
sway bars shehan1212 NY / NJ / CT / PA 1 03-18-2014 10:17 PM
BRZ / F86 Sway bars timlewis82 AUSTRALIA 1 11-11-2013 02:53 AM
brz and fr-s sway bars different? 1010110 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-03-2013 01:43 AM
ST sway bars bmxhotsauce Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-09-2013 03:11 PM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 06:00 PM
