Drives: 4-Runner Sport - 13' BRZ SportTech
Quiet sway bars
Can anyone recommend a front and rear sway bar combo that is SILENT?
I rolled the dice on a set of Hotchkis sway bars and they clunk like crazy. It's both the front and rear, and I've tried a few different endlinks. Tightening the links quietens them down a bit, but not for long. They usually stay quiet for a couple of days then go back to making noise. I've tried loctite and lock washers, but they keep backing off a very slight amount. I'm thinking the bolt holes on the bars themselves are slightly larger than the endlink bolt diameter. Anyways, can anyone recommend a front and rear sway bar set that is dead silent? I just can't take the clickiing/clunk noises anymore. I'm thinking Perrin
Top Tier Imports - Check out my build journal HERE
#2 |
i'm sorry, what?
Drives: Canada
a swaybar by itself cannot clunk, it has no moving parts
if it is clunking, there is metal on metal contact due to binding and improper articulation
#3 |
Are your bushings nice and lubed up? Wrapping the bar in teflon tape at the bushings helps as well.
- Andy |
#4 |
Drives: Scion FR-S 2013 Raven
I run Hotchkis in front and no noise for me. What is your drop?
o= FR-S =o |
#5 | |
Are you using OEM end links?
#6 |
Drives: 2019 Mazda Miata RF
I'm going to be installing a set of Hotckis bars tomorrow, I'm curious what's making the noise.
#7 | |
Drives: 2005 Toyota Camry
Otherwise, you're just binding/preloading the links and they'll always become "loose" after you start driving the car. -alex |
#8 |
Default User Title
check the torque on your top nuts.
#9 |
0.8" on the front and oem link yes.
o= FR-S =o |
#10 |
The top hats on the coilovers?
Sent from my HTC One using Tapatalk
#11 |
Default User Title
#12 |
Are you sure you aren't getting any knocking from the swaybar to lower control arms? At a 1.5" drop and stock end links I would bet that's a strong possibility.
#13 |
Default User Title
That was my thought when I was hearing the clunking, I am lowered about 1.5 with oe endlinks too. No contact, just slightly loose top nuts. It is easier to check them first.
#14 |
The stock end links are too long. I went to whitelines , same knock. Got the oems shortened 50mm, same knock
It's fine at first but then the bolts back off a bit and it comes back. I'm pretty sure the bolt hole on the bar is slightly too large and it moves around Sent from my HTC One using Tapatalk
| sway bars | shehan1212 | NY / NJ / CT / PA | 1 | 03-18-2014 10:17 PM |
| BRZ / F86 Sway bars | timlewis82 | AUSTRALIA | 1 | 11-11-2013 02:53 AM |
| brz and fr-s sway bars different? | 1010110 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 08-03-2013 01:43 AM |
| ST sway bars | bmxhotsauce | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 05-09-2013 03:11 PM |
| FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! | NJA | Brakes, Suspension, Chassis | 18 | 04-07-2013 06:00 PM |
