Drives: 2013 Scion FR-S Manual in Whiteout
brz and fr-s sway bars different?
Does anybody know if the sway bars are the same or different between the fr-s and brz?
I have an fr-s and I would like to upgrade the suspension, but retain the balance of the fr-s. I already installed swift fr-s springs and would like to upgrade sway bars as well, but would like to maintain the balance of the fr-s and not turn my car into a brz. The RCE sway bars look nice, but I'm not sure if they are designed to maintain the balance of the fr-s or brz. Thoughts? |
Drives: '13 BRZ / '11 Outback / '06 Tundra
frs and brz use the same sway bars.
| The Following User Says Thank You to celica73 For This Useful Post: | 1010110 (07-25-2013) |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
The RCE Hollow Sways do a great job of maintaining the oversteeryness of the car after installing lower/stiffer springs. I have the front set to the softer setting and the rear at the stiffer setting and they suit my needs perfectly. The key is that the RCE sways are adjustable so you can play around with different settings to dial in the handling you prefer.
Check out some of my track footage to get a better idea of how the car behaves at the limit. It will still rotate and oversteer but it does so much less often when running sticky tires. The grip and turn-in responsiveness is dramatically increased from just the RCE sways and some negative camber all around. It's still very tail happy on the stock wheels and tires if you purposefully toss the car around. |
| The Following User Says Thank You to ATL BRZ For This Useful Post: | 1010110 (07-25-2013) |
#4 | |
Drives: 2005 Toyota Camry
By modifying the suspension with aftermarket components, you're making the FRS more like a BRZ (and vice versa). -alex |
I was not commenting on the balance of the fr-s compared to the brz. What I was trying to say is that I would like to maintain the handling characteristics of the fr-s, specifically the tendency to oversteer, while upgrading the suspension.
#6 | |
No they are completely silent. Using the stock end links as well.
#8 | |
Thanks for the recommendation, much appreciated. |
| The Following 2 Users Say Thank You to 1010110 For This Useful Post: | ATL BRZ (08-03-2013), Racecomp Engineering (08-03-2013) |
| Tags |
| racecomp engineering, rce, swift racing technology |
| ST sway bars | bmxhotsauce | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 05-09-2013 03:11 PM |
| FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! | NJA | Brakes, Suspension, Chassis | 18 | 04-07-2013 06:00 PM |
| Sway bars in AutoX. | IloveBaldEagles | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 04-01-2013 06:21 PM |
| Cusco Sway Bars? | wootwoot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 08-04-2012 05:31 AM |
| adjustable sway bars!!! | carbonBLUE | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 05-04-2012 08:42 AM |
