Drives: Whiteout FRS
key keeps getting stuck
Hey guys so my key keeps getting stuck in my ignition. anyone know how i can fix this and does anyone else have this problem it happens every time i try to take the key out and it's only been happening since yesterday.
You might try dabbing a bit of silicone on the key and inserting & extracting several times to losen up the tumblers.......
![]() Also, try "jiggling" the steering wheel a bit while pulling out the key. humfrz Back in the day, we would just squirt some 3in1 oil in the ignition lock, heat up the key with a Zippo cigarette lighter and stick er in. Last edited by humfrz; 04-21-2014 at 11:29 AM. |
#3 | |
Drives: Subaru BRZ Limited
#4 | |
).Back in 1970 I bought a brand new MGB-GT (in BRG). Yep, I terrorized most all of the curvy back roads around Santa Cruz, CA. A feature on that car was that when you pulled the key out and turned the steering wheel a bit, the steering column would lock (an anti-theft feature). Well, one day, in the mail, I received a re-call notice. I was to carefully bring my MG back to the dealership to have the steering column lock replaced. What had happened on several cars, was that the steering column would lock when the wheel was turned ..... with the key in the ignition ..... WHILE DRIVING DOWN THE ROAD ..... ![]() Now THAT was a "careful" drive to the dealership the next day .... ![]() Yes, it's past time for my meds and nap .... ![]() humfrz |
Drives: 2013 - Scion FR-S in White"red"out.
Could have something to do with the steering wheel lock. I had that problem on my old 911 and had to turn the steering wheel a little to get it to release my key.
| The Following User Says Thank You to ilpad For This Useful Post: | Covo_86 (04-21-2014) |
Drives: small
BRZ, 10 series, monogram or RS1.0
I'll never buy a new car that uses keys in the ignition again. Probably doesn't help, sorry. |
| The Following User Says Thank You to Boxer486 For This Useful Post: | Covo_86 (04-21-2014) |
#10 |
Hmm I'll have to think long...and hard...about that one.
| The Following User Says Thank You to Burrcold For This Useful Post: | humfrz (04-20-2014) |
#11 | |
However if you drop your keys when they hit the ground it can cause small burrs on the key that then makes it stick in lock, use a fine sandpaper or wire brush to remove any burrs (don't grind off and make it all smooth though )
| The Following User Says Thank You to steve99 For This Useful Post: | Covo_86 (04-21-2014) |
#12 | |
#13 |
I appreciate the positive reinforcements for the suggestions in post #2........
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Covo_86 (04-21-2014) |
#14 |
Drives: BRZ Limited SWP
Also if you have a lot of keys on your same key chain all the weight could affect your key, people don't seem to realized that when you have 3 lbs of weight on your key chain it does where out your key a lot faster and could break in your ignition.
And also I agree with ilpad it could be something with your wheel lock, so if the lube doesn't work, I would have it checked out before you sleep in your car because you can't get the key out. good luck. |
| The Following User Says Thank You to dannyboy8793 For This Useful Post: | Covo_86 (04-21-2014) |
| Got stuck in the snow | DoopaTroopa | Mid-Atlantic | 40 | 03-06-2014 06:16 AM |
| O2 Sensor stuck... | ThisGuy919 | Engine, Exhaust, Transmission | 13 | 10-18-2013 04:58 AM |
| I'm Stuck In A Dilemma | ALbadboy | BRZ First-Gen (2012+) — General Topics | 30 | 02-25-2013 07:02 PM |
| stuck in buffalo NY | FT86R | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 07-16-2012 09:29 PM |
