Old 04-20-2014, 03:16 PM   #1
Covo_86
Covo_86's Avatar
Drives: Whiteout FRS
key keeps getting stuck
Hey guys so my key keeps getting stuck in my ignition. anyone know how i can fix this and does anyone else have this problem it happens every time i try to take the key out and it's only been happening since yesterday.
Covo_86 is offline   Reply With Quote
Old 04-20-2014, 03:31 PM   #2
You might try dabbing a bit of silicone on the key and inserting & extracting several times to losen up the tumblers.......
Also, try "jiggling" the steering wheel a bit while pulling out the key.
Back in the day, we would just squirt some 3in1 oil in the ignition lock, heat up the key with a Zippo cigarette lighter and stick er in.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Burrcold (04-20-2014), Covo_86 (04-21-2014), Kuri (04-21-2014)
Old 04-20-2014, 04:06 PM   #3
Burrcold
Drives: Subaru BRZ Limited
Back in the day, we would just squirt some 3in1 oil in the ignition lock, heat up the key with a Zippo cigarette lighter and stich er in.
Great advice, my wife couldn't agree more
Old 04-20-2014, 04:22 PM   #4
Originally Posted by Covo_86 View Post
tried jiggling the wheel it didn't work sometimes it comes it just takes time. just weird the car only has 8000 miles thought it was more common with older cars i'll try the silicone. thank you
That reminds me of a story (ya I know .... ).
Back in 1970 I bought a brand new MGB-GT (in BRG). Yep, I terrorized most all of the curvy back roads around Santa Cruz, CA.
A feature on that car was that when you pulled the key out and turned the steering wheel a bit, the steering column would lock (an anti-theft feature).
Well, one day, in the mail, I received a re-call notice. I was to carefully bring my MG back to the dealership to have the steering column lock replaced.
What had happened on several cars, was that the steering column would lock when the wheel was turned ..... with the key in the ignition ..... WHILE DRIVING DOWN THE ROAD .....
Now THAT was a "careful" drive to the dealership the next day ....
Yes, it's past time for my meds and nap ....
Covo_86 (04-21-2014), raptor87 (04-20-2014)
Old 04-20-2014, 04:53 PM   #5
......but....but.....where does the Zippo lighter fit in .....
Old 04-20-2014, 04:58 PM   #6
ilpad
ilpad's Avatar
Drives: 2013 - Scion FR-S in White"red"out.
Could have something to do with the steering wheel lock. I had that problem on my old 911 and had to turn the steering wheel a little to get it to release my key.
ilpad is offline   Reply With Quote
The Following User Says Thank You to ilpad For This Useful Post:
Old 04-20-2014, 05:03 PM   #7
Boxer486
Drives: small
BRZ, 10 series, monogram or RS1.0
I'll never buy a new car that uses keys in the ignition again. Probably doesn't help, sorry.
Boxer486 is offline   Reply With Quote
The Following User Says Thank You to Boxer486 For This Useful Post:
Old 04-20-2014, 05:12 PM   #8
Covo_86
Covo_86's Avatar
yeah that's what i though i tried that and it didn't work just a little strange i'll figure it out
Old 04-20-2014, 05:13 PM   #9
Covo_86
Covo_86's Avatar
probably shouldaa went with the push button start haha
The Following User Says Thank You to Covo_86 For This Useful Post:
Kuri (04-21-2014)
Old 04-20-2014, 06:05 PM   #10
Burrcold
Hmm I'll have to think long...and hard...about that one.
The Following User Says Thank You to Burrcold For This Useful Post:
humfrz (04-20-2014)
Old 04-20-2014, 06:20 PM   #11
steve99
Drives: FT86
You could wipe on a small amount of lubricant onto key.
However if you drop your keys when they hit the ground it can cause small burrs on the key that then makes it stick in lock, use a fine sandpaper or wire brush to remove any burrs (don't grind off and make it all smooth though )
Old 04-20-2014, 06:25 PM   #12
Covo_86
Covo_86's Avatar
yeah i'm gonna try the spare key out
Old 04-20-2014, 08:10 PM   #13
I appreciate the positive reinforcements for the suggestions in post #2........
Old 04-21-2014, 08:09 AM   #14
dannyboy8793
dannyboy8793's Avatar
Drives: BRZ Limited SWP
Also if you have a lot of keys on your same key chain all the weight could affect your key, people don't seem to realized that when you have 3 lbs of weight on your key chain it does where out your key a lot faster and could break in your ignition.
And also I agree with ilpad it could be something with your wheel lock, so if the lube doesn't work, I would have it checked out before you sleep in your car because you can't get the key out. good luck.
dannyboy8793 is offline   Reply With Quote
The Following User Says Thank You to dannyboy8793 For This Useful Post:
Got stuck in the snow DoopaTroopa Mid-Atlantic 40 03-06-2014 06:16 AM
O2 Sensor stuck... ThisGuy919 Engine, Exhaust, Transmission 13 10-18-2013 04:58 AM
I'm Stuck In A Dilemma ALbadboy BRZ First-Gen (2012+) — General Topics 30 02-25-2013 07:02 PM
stuck in buffalo NY FT86R Scion FR-S / Toyota 86 GT86 General Forum 5 07-16-2012 09:29 PM
