Old 10-15-2013, 04:43 PM   #1
ThisGuy919
O2 Sensor stuck...
Been trying to get this O2 sensor off all day. First one came off pretty easily but this one... its pretty stuck. tried an impact wrench (electric seem'd weak), muscling it with a wrench, and tried muscling again with an o2 remover socket. Nothing worked.. Took it to the dealer and they could'nt get it off either. Anyone have a solution for this? Trying to reuse the o2 sensor so i dont want to spray any PB blaster on it (hear it ruins the sensor).
ThisGuy919 is offline   Reply With Quote
Old 10-15-2013, 04:46 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
If an O2 remover socket and a 1/2" breaker bar didn't get it out, then I am not sure you are going to be able to save it and I would resort to some rust penetrant.
The Following User Says Thank You to King Tut For This Useful Post:
Sportsguy83 (10-15-2013)
Old 10-15-2013, 05:05 PM   #3
jamesm
breaker bars solve all the world's problems. at least the important ones.
The Following User Says Thank You to jamesm For This Useful Post:
Old 10-15-2013, 05:07 PM   #4
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
CHHHEEEEEEAAAAATTTTT!
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 10-15-2013, 05:16 PM   #5
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
PB Blaster (just go easy) work it back and forth, in stages, until it turns easy.
You will probably still end up with buggered threads on the sensor - If you happened to make any progress with the impact/breaker, without the PB Blaster, that movement was probably the the expense of the threads.
The heat from the cat causes this. I had the same thing happen, PB blaster was the only way I could get it out, but the threads were trashed. Luckily for me, I had a spare Toyota O2 sensor in my bin of parts. I just had to hack off the end and solder on a male vs. female plug (same exact style plug). I also had a spare connector in my parts bin.
uspspro is offline   Reply With Quote
Old 10-15-2013, 08:58 PM   #6
Calum
That Guy
Drives: 2013 asphalt FRS MT
um... heat?
Or perhaps use the noisy cricket approach. Use an impact gun set low and just let it sit there banging away for awhile. If the sensor doesn't move after 5 minutes move the gun to the next setting and try again. A pair of ear plugs is recommended as the noise will quickly get annoying/painful. It takes a while but it's never failed me and VERY few threads have come out messed.
Old 10-15-2013, 09:02 PM   #7
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
I've came across this 7 different times on customers twins. There's just certain headers that get stuck and it's always that sensor. I have been able to save 1 of the 7 that got stuck, the others were ruined and had to be replaced. I keep those in stock now because it was happening so often.
Pure Automotive is offline   Reply With Quote
Old 10-15-2013, 09:03 PM   #8
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
I've never ruined a sensor with PB personally and have used it several times on my FR-S's o2 sensors.
SloS14 is offline   Reply With Quote
Old 10-15-2013, 09:04 PM   #9
Pure Automotive
This is not a situation where PB fixes the problem, the ones that I have had stuck are cross-threaded from the factory.
Old 10-15-2013, 09:04 PM   #10
aagun
Drives: 86
heat it >>>
aagun is offline   Reply With Quote
Old 10-15-2013, 09:10 PM   #11
SloS14
SloS14's Avatar
Sorry, I should have clarified. PB is short for NPBBWTFT (New PB Blaster with thread fixing technology).
I hope the factory isn't getting these things on by half a thread then zipping them on.
Old 10-18-2013, 03:02 AM   #12
ThisGuy919
Got it off that night and man was it cross threaded...by the time we got it out the threads were obliterated. o.O pb blaster did the trick. Wanted to avoid it because of that slight chance it will seep into the sensor itself... Ended up working out.
Old 10-18-2013, 03:18 AM   #13
ft86me
ft86me's Avatar
Drives: 2013 FRS
WD40 is what we use at my shop when this happens. try an open ended wrench as well. if not try a 02 sensor removal tool that looks like a 12point and is short. the longer, the less power you put down. hope this helps. haven't run across an 02 sensor i couldn't take off with the previous things over a span of 8 years.
oh almost forgot, try to tighten a bit then go back to trying to loosen it. sometimes tightening will get it to budge. so little umph tightening then try to loosen. if it budged then you're good and if it's super hard to spin with the wrench. do the same motion with wd40 over and over until it's out with of course the loosening having more umph than tightening. hope this helps.
ft86me is offline   Reply With Quote
Old 10-18-2013, 04:58 AM   #14
Fast_Freddy
Drives: Passat
WD40 or PB Blaster won't help much when the sensor is badly cross-threaded from the factory. I had a hell of a time getting mine out and 1/2 the threads were stripped off. Using gunsmithing files I was able to clean up the threads just enough to get the sensor threaded into a mini-cat.
Fast_Freddy is offline   Reply With Quote
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
I'm Stuck In A Dilemma ALbadboy BRZ First-Gen (2012+) — General Topics 30 02-25-2013 07:02 PM
stuck in buffalo NY FT86R Scion FR-S / Toyota 86 GT86 General Forum 5 07-16-2012 09:29 PM
