Drives: 2013 MT Asphalt FRS
Can someone check their engine for me?
I uploaded a video a few days ago regarding a ticking sound I been having after installing my headers and FP/OP. Frs: [ame]http://youtu.be/xoNSVgxRq2U[/ame]
A coworker checked to see where the sound was coming from and he believes it's coming right below the alternator. Not sure what that part is called but it does vibrate and thinks a screw is missing. Can anyone confirm that?
Drives: 2014 BRZ - 2004 GLI
There's no screw there on mine. Just a plastic insert that goes into thin air.
What kind I headers did you buy? Any leaks?
Just drive it
Drives: 13' FR-S
Did you check any exhaust leaks?
Before cold start, spray soapy water on each gaskets and start the engine. It sounds like exhaust leak for me if these happened right after installing all those aftermarket parts. |
Drives: 2015 Scion FR-S
What you have circled is part of the automatic tensioner for the serpentine belt setup. The sound you have is due to exhaust leaks. Buy new gaskets for all connections (although it sounds like it's at the head/header because one pulse sounds louder, rather than a constant hiss), reinstall everything, and torque to factory specs.
Drives: JAWS
you could try driving it for a few days, then retorquing all of the bolts. The expansion and contraction of the metals and retorquing might help.
#7 | |
![]() humfrz |
Drives: 2013 FR-S Firestorm
Here's mine acting normally.
[ame="http://youtu.be/ZE8xBtMEtoU"]http://youtu.be/ZE8xBtMEtoU[/ame] |
#9 | ||
Nameless |
#10 |
#11 |
#12 |
Holy exhaust leak!
1) Buy welding leathers (to shield from heat in later steps) 2) Buy Any tools needed to get you as far as possible from header for installation 3) Jack up car 4) Give slight torque to bolts on header on all flanges. Loosen all exhaust flanges and tighten header <-> engine flanges first. Torque to spec 5) Start car. Let idle for 2-5 minutes (until warm) 6) Re-torque starting at header flanges. Heads will physically shift place causing the headers to shift placement, possibly loosening. 7) Let things cool verify they are still within spec. Let it cool down, start car and feel for exhaust leaks (do so with caution).
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#13 | |
(keep in mind it doesn't just happen under throttle that was just this guy on the videos case lol)
#14 |
Drives: SWP BRZ
yeah re-install form header to back again. that's really bad
| Will I get a check engine light on if the engine bay has a direct injection failure? | Astroboy | Engine, Exhaust, Transmission | 7 | 03-29-2014 06:16 PM |
| What does it mean when tractions off and check engine come on? | Frs32907 | Issues | Warranty | Recalls / TSB | 8 | 01-24-2014 09:33 AM |
| Check engine light? | czar07 | AUSTRALIA | 0 | 09-01-2012 02:50 AM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
| Check Engine Light | b.e | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 06-17-2012 09:50 PM |
