Drives: None
Will I get a check engine light on if the engine bay has a direct injection failure?
Last week I was driving my car when all of the sudden I had multiple check engine light came on that my car was running to rich. I have it flash tuned with a header back exhaust and a fa20club true cold air intake. I took the car home right away and had it tuned back to stock and the light was off. The only time I get stuff like this going on is when I spend a lot of time driving on the map where it rev matches automatically when your driving past 3k rpm then hit the brakes and clutch while shifting gears.
Sent from my iPad using Tapatalk |
Drives: I own an FR-S. . . whatelse!
I might be wrong, but when DI failure happens it generally runs lean and not rich.
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Did you read the code?
- AdrianG |
How rich was it running? Do you have a wideband o2 sensor?
- AdrianG |
The Answer
Drives: Mazda 2
Should have read the code bro
#7 | |
Drives: None
The codes came up as running rich and so did the car skidding light inside the rev meter but when I checked the afr on my obdii reader and torque app it showed it was running at 14 which is odd. No I don't have a wideband o2 sensor.. Sent from my iPad using Tapatalk |
Drives: None
| Engine Check Light..HELP | AZOOZ_95 | Engine, Exhaust, Transmission | 10 | 02-09-2014 03:20 PM |
| Check engine light. Help!!!!! | sf86 | Issues | Warranty | Recalls / TSB | 2 | 06-05-2013 03:51 AM |
| Check engine light? | czar07 | AUSTRALIA | 0 | 09-01-2012 02:50 AM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
| Photos of Subaru Boxer 1.6L Direct Injection Turbo DIT Engine from 2011 TMS | Hachiroku | BRZ First-Gen (2012+) — General Topics | 21 | 12-01-2011 07:52 AM |
