Old 06-16-2012, 07:05 PM   #1
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
Check Engine Light
My check engine light was triggered today. The code that came up indicated the ECU lost communication with the dashboard instruments (or something like that). I can guess it was the presence of my cheap Chinese Bluetooth ECU reader I was using next to a power plant. Maybe the big electric fields were picked up by the unshielded/ungrounded reader.
What really surprised me is how gimped the vehicle becomes when the check engine light comes on: 4000 rpm limit, no cruse control, automatic gears messed up. The automatic may have messed up because of the rpm limit, but I had to switch to manual mode to drive comfortably on the highway back to the dealer's repair shop. All they did was the reset, so if I get the same error I can do that part myself.
This car drives very weird if you can't go over 4000 rpm. It just sort of get's stuck in gear, revved at 4k, and won't up-shift by itself. Like I was driving my old Chevy Sprint.
b.e is offline   Reply With Quote
Old 06-16-2012, 07:34 PM   #2
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Interesting. So it has a safety mode. That's kind of neat as long as it doesn't happen due to minor issues like the fuel cap not being completely sealed.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 06-16-2012, 09:42 PM   #3
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Does this mean that a cai throwing a cel will put your car in limp... The first frs we got at the desler had a cel after 10 miles or so
Silverdub is offline   Reply With Quote
Old 06-16-2012, 09:49 PM   #4
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
How did they reset it?
Old 06-16-2012, 09:50 PM   #5
yayforaddison
yayforaddison's Avatar
Drives: Whiteout FR-S
Almost sounds like a possible transport mode
yayforaddison is offline   Reply With Quote
Old 06-16-2012, 10:09 PM   #6
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
Talk about nerf! thats actually kind of scary. Imagine getting the CEL on a long road trip and super nanny kicks in? Or in the middle of the highway doing some highly spirited driving? Interesting indeed... Unless ofcourse it was just your car in particular that has this "super nanny"
Exhaust is offline   Reply With Quote
Old 06-16-2012, 11:40 PM   #7
b.e
If it's just my car, she has no reason to be jealous yet. I haven't even so much as looked at another car since getting her.
Old 06-16-2012, 11:47 PM   #8
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
if you do not have an OBD2 scan tool to clear the code. Disconnect the negative battery cable from the terminal for a few minutes. If you do not have time to wait, disconnect the positive (do not mix this up) battery cable and touch it to the negative (GND) battery terminal and re attach it. Nothing like that will likely be a hard code which requires a scan tool to reset.
mines13 is offline   Reply With Quote
Old 06-17-2012, 04:36 PM   #9
Toy86
Toy86's Avatar
Drives: 2013 VW Scirocco R
+1 please answer - I use to be able to do it by Disconnecting the battery and then pumping the break pedal.
Toy86 is offline   Reply With Quote
Old 06-17-2012, 09:50 PM   #10
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
No clue what it had but simply scan it and see a generic obd2 scanner will do
Check Engine Light directly after pickup Stu L Tissimus BRZ First-Gen (2012+) — General Topics 27 06-15-2012 05:07 PM
Check engine light code reader FRSCoupe Engine, Exhaust, Transmission 14 06-13-2012 05:06 PM
Got to check out the FR-S... r4m3n FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 75 03-02-2012 09:18 AM
Check in, eh? NorthFool CANADA 24 02-23-2012 07:32 AM
Check this out nogaroblues4 Electronics | Audio | NAV | Infotainment 6 02-20-2012 08:34 PM
