Long Start
Anyone else having an issue with a long start after a period of driving?
Example:
I'm not talking an obnoxious amount of cranking, but easily double when the car is cold. Also I should note it has never failed to fire up. I just think it's weird because typically a car would FTF when it's cold, not warm. Any thoughts? |
Drives: 2013 PW Toyota GT86 with body kit
Same thing happens to me, but if I enter the car and give it 5 to 10 seconds it starts up normally.
I hope that helps. |
Add my BRZ has having this issue. It's quite noticeable with the push start since I'm used to pushing, waiting for 2 cranks, then setting off. These longer cranks are like 4-6 cranks before the engine will cough to life.
It sounds kinda like what my older coworkers would describe as vapor lock on a carbureted car. |
The only thing i can think of is if the ECU is determining whether or not to start in closed or open loop. Not sure if that's even possible, just a thought.
Thanks
I usually start when I hear fuel pump finish priming, haven't had any problems
Drives: 13 FRS
Drives: '16 WRX, CBR1000RR
This is common on motorcycles too. All of my bikes have done this to an extent. I chalk it up to heat soak, the engine is just harder to start when all the engine components are hot.
Drives: BMW 228i TPK , 13 BRZ (LemonLawed)
I've actually had trouble recently with mine not even attempting to start. The push button will turn the car on, but it won't start it. It's happened about 5 times in the last month and a half. When it happens I've had to cycle through all the modes as many as 6-7 times and then it'll crank. I contacted the dealer and they weren't any help. I thought the key might have a weak battery, but that wasn't it, and the clutch is all the way in when I start it. I did have the High Pressure Fuel Pump replaced recently. Has anyone else experienced anything similar? I did a search, but didn't see anything.
#10 | |
#11 |
On mine, and other cars I've owned that did this, if I armed the car and ignition, but held off on pushing the clutch in (and engaging the starter) until after I hear the fuel pump finish priming, and after the tach had finished with it's sweep.
This always helped with long cranks when really hot. |
#12 |
Drives: Series 10 #177 M/T
Mine did this today for the first time (999 miles). It cranked over for a good 10 seconds before firing up. I tried turning it off and back on when I got home and it wouldn't start. I'll try again in the morning.
Also, I can't find a PDF on that TSB. Is that a TSB or an SSB? |
#13 |
I experienced the same issue about a month ago. Clutch in, pressed the start button, and took it about 7 cranks to start the engine up.
I've had previous vehicles that featured a start button and this is a first for me. Is there a TSB for this issue? |
#14 |
Drives: 2005 Toyota Camry
| Long start up. Not weather related. | Liquidsnake | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 03-28-2015 06:39 AM |
| Cinco de Slamo Meet in Long Beach NY (Long Island) | whitefrs | New England | 11 | 05-01-2013 09:03 AM |
| Pop-Start with Push-Button Start | cmspooner | BRZ First-Gen (2012+) — General Topics | 5 | 03-22-2013 02:45 PM |
| How long to hold push button start. | Dorb | BRZ First-Gen (2012+) — General Topics | 11 | 01-21-2013 05:57 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 03:44 AM |
