Old 01-20-2013, 01:30 PM   #1
Dorb
Drives: 16 LM STI/13 LM BRZ/04 AVALANCHE
How long to hold push button start.
I was holding it in until the car turned over, but lately I have just been pushing and releasing. Any idea which is correct or is this really a non issue? Both ways start car, just wondered if one was better on the car then the other.
Dorb is offline   Reply With Quote
Old 01-20-2013, 01:35 PM   #2
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
If you read the manual, it's states to simply give it a "firm" push and release. But otherwise yes both ways work!
Gords_zenith is offline   Reply With Quote
The Following 2 Users Say Thank You to Gords_zenith For This Useful Post:
chanomatik (01-21-2013), Dorb (01-20-2013)
Old 01-20-2013, 01:36 PM   #3
TOMIMOTO
TOMIMOTO's Avatar
Drives: MY00 Impreza 2.5RS
I haven't had the opportunity to try out a Subaru push start yet, but in every car ive driven that has it, all it needs is a simple push.
It's not like turning a key if you hold the button down.
TOMIMOTO is offline   Reply With Quote
Old 01-20-2013, 01:38 PM   #4
Dorb
Not sure how I missed that. Thanks.
Old 01-20-2013, 04:53 PM   #5
BRZnut
Drives: BRZ DGM Limited
push and let go! (I was doing the same thing at first and keeping it pushed until the car would turn over)
Old 01-20-2013, 09:49 PM   #6
Gords_zenith
No problem. Also, just want to say sorry, as I re-read what I posted a couple of hours later and realized I came across as a bit of a ****...
Old 01-21-2013, 07:07 AM   #7
Dorb
Nah, your good.
Old 01-21-2013, 09:09 AM   #8
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Don't hold the button until car starts. My experience with push start before was that i usually press and hold the button until the car starts, but sometimes the car starts then it shuts off cause i've been pressing too long.
chenshuo is offline   Reply With Quote
Old 01-21-2013, 01:32 PM   #9
Andrew360
Andrew360's Avatar
Drives: Whiteout FRS, 07 Stg 2 Vw GTI
I have a different question. How long should I hold the clutch when starting?
Andrew360 is offline   Reply With Quote
Old 01-21-2013, 02:41 PM   #10
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
Until you move it out of gear...
Or you will have a continuous fun time stalling the car.
Old 01-21-2013, 02:59 PM   #11
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Do you mean, with the transmission in neutral? If so, that's a good question. There's an interlock that keeps the starter from engaging without the clutch depressed, so you have to depress it long enough to engage the starter.
I had hoped that that was enough; IOW, if the starter engages, you could then release the clutch. But it isn't - if you release the clutch before the engine catches, the starter disengages and you're out of luck.
FWIW this isn't unique to the BRZ; my Corvette works the same way. I understand the safety reasoning, but it's kind of a drag - in older cars I used to start without depressing the clutch (in neutral, of course), because the pressure plate preloads the rear main with an axial load - it's theoretically easier on the engine to start it with the clutch engaged.
I had a car with the interlock in the '90s that was set up such that I could stick my left toe up behind the clutch pedal and press the button that sensed clutch activation; I just trained myself to do that. But that's not possible (or at least practical) with the BRZ.
Admiral Ballsy is offline   Reply With Quote
Old 01-21-2013, 05:57 PM   #12
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
Most cars with push button start are the same. My M3, Corvette and Rav4 were all the same. Push and release and it will take care of the rest.
Jaylyons1 is offline   Reply With Quote
STI Push Button Start Proud of BOXER Cosmetic Modification (Interior/Exterior/Lighting) 117 08-05-2019 05:19 PM
Push Button start... usptwins DIY (Do-It-Yourself) Guides 155 07-31-2019 11:10 AM
TRD push start button nix Australia Classifieds 1 11-27-2012 12:53 AM
Push button start Symbiont Cosmetic Modification (Interior/Exterior/Lighting) 5 06-17-2012 01:45 PM
push button start standard? sparrowhawk BRZ First-Gen (2012+) — General Topics 2 03-04-2012 03:52 PM
