Old 03-22-2013, 11:16 AM   #1
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
Pop-Start with Push-Button Start
My small engines class and I were wondering if it is possible to pop-start a BRZ with the push button start by rolling it down a hill and popping it in gear. Any thoughts or experiences with it?
cmspooner is offline   Reply With Quote
Old 03-22-2013, 11:28 AM   #2
Timmy_Jones
Spun
Drives: 23' Supra
If it has a manual trans, then yes. Think of your push button start like a key. Instead of twisting, you push.
Also, my CBR 600 was a push button start, had to roll start it a few times with no issues.
Timmy_Jones is offline   Reply With Quote
Old 03-22-2013, 11:47 AM   #3
infinite012
Drives: 13 DGM BRZ Ltd
If the car still has a working battery with a charge, press the start button twice without pushing the clutch in to start all electronics. Push the clutch in, set the car to 2nd gear, have people push the car, pop the clutch, drive away.
I'm not even certain you need the battery to have a charge. You can just pop start it like you normally would.
infinite012 is offline   Reply With Quote
Old 03-22-2013, 12:20 PM   #4
brzadrian
I'm Batman
brzadrian's Avatar
Drives: 2013 Subaru BRZ aka Sally
what about the steering?
has anyone tried this?
i was wondering about this hill start as well
brzadrian is offline   Reply With Quote
Old 03-22-2013, 12:33 PM   #5
welllam
Drives: STi
hvnt popped brz but popped a keyless 08 sti with same system. Double click to the starting ceremony and the u can pop the clutch.
However, the cluster will go blinking like there's Ecu error and ABS and traction control not working, but there's still boost. To fix this, you need to shut down the car and complete another starting ceremony and wait. Once everything ready u start the car in a normal way then everything goes back to normal.
In short don't do it unless its necessary.
Sent from my GT-N7105 using Tapatalk 2
welllam is offline   Reply With Quote
Old 03-22-2013, 02:45 PM   #6
cmspooner
cmspooner's Avatar
I was wondering about all of the electronics including the direct injection system. I guess that it gets started up on crankshaft rotation. Thanks; I'll share your feedback with my class.
STI Push Button Start Proud of BOXER Cosmetic Modification (Interior/Exterior/Lighting) 117 08-05-2019 05:19 PM
Push Button start... usptwins DIY (Do-It-Yourself) Guides 155 07-31-2019 11:10 AM
genuine push button start sprang86 Australia Classifieds 0 02-02-2013 08:33 PM
TRD push start button nix Australia Classifieds 1 11-27-2012 12:53 AM
Push button start Symbiont Cosmetic Modification (Interior/Exterior/Lighting) 5 06-17-2012 01:45 PM
