| Northern California NorCal |
Overpipe knocking?
Is anyone else on the forum running the Agency Power Overpipe/Frontpipe slip in unit?
After installing, I started hearing and feeling "knocking". noticeable mostly when accelerating in 1st gear; either while turning from a dead stop(for example, making a U-turn) or accelerating hard from a dead stop. Took the car to my local exhaust shop and saw that the overpipe itself was touching the cross-member shield that rides upward between the engine block and strut tower. The technician loosened the flange between the over pipe and front pipe then temporarily, put a bar in there to separate the touching metal, gave it a few pushes to open up a gap, let the pipes cool down, bolted and tightened everything back and then removed the bar. It made a noticeable gap of space and the OP was now free of touching anything. It helped for about a day or so but now I'm hearing the knocking again. Running OEM Headers and OEM midpipe still btw. Sorry for the novel, trying to be as detailed as possible. Any ideas or help/advice would be appreciated. Thanks in advance. Sent from my iPhone using Tapatalk
SBD Turbo V2 | OFT Flexfuel Kit; Tuned by Shiv @10psi | Nameless 2.5in. 1-piece OP/FP | Full Custom Center Exit/SS dual tip cat-back exhaust | KateCOOL Oil Cooler | Mishimoto T-Stat sandwhich plate | ACT XT Street Clutch Kit; 10.5lb flywheel | RSR Black-i Coilovers | Rota Torque 17x9 +30 | Bayson R front lip/side skirts/rear spats and rear windshield visor
Replace it with a better quality piece.
Awesome input lol very helpful
#4 | |
Eliminate the problem or mask the problem?
I was more looking for someone to chime in who has or has had a similar issue. Unless you would like to purchase me new parts, I like to see if I can take it upon myself to fix the issue first before giving up
#6 | |
Wrap it may help but it isn't fixing the issue. Can't you return it citing bad figment?
Not entirely, I took it off a friend used. Who had no issues with it while on his car, although he was running an aftermarket header. Maybe that is what's needed, which sucks to know even though they claim the part works with oem headers.
#8 | |
Drives: LR BRZ
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Joking aside, maybe the problem is in the fitment. I'm having trouble picturing it, but I would try to loosen up all the other pieces and see if you can adjust any of them to get any extra room, although I'm positive your exhaust shop would have tried that already.
#10 |
Drives: WRB BRZ
Are you sure it is just hitting the cross member? I had mine hitting the swaybar.
In the garage:
1988 BMW E30 M3 2003 Ducati ST4s ABS 2006 Subaru Legacy GT Spec B #444/500 (For Sale) 2013 Subaru BRZ WRB Limited - Acquired 9/15/12 |
#11 | |
Should have taken pictures when I was under there with the car on his lift lol. Sent from my iPhone using Tapatalk
#12 | |
How did you know it was hitting your sway? And just to clarify you were also running oem headers + agency power over pipe & front pipe? Sent from my iPhone using Tapatalk
#13 |
Poor College Kid
Drives: ~.~
What are you selling bro?!
OP- That sounds weird, did you have your friend check it out since he didn't have any issues with his?
#14 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Motor mounts
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
| Knocking sound | Moe23 | Issues | Warranty | Recalls / TSB | 80 | 04-18-2019 08:09 PM |
| Knocking doesn't sound good :-(. | TheMarkness | Issues | Warranty | Recalls / TSB | 41 | 02-04-2015 10:38 PM |
| Knocking on Startup? | 636 | Issues | Warranty | Recalls / TSB | 17 | 02-03-2014 07:18 AM |
| Knocking/Rattle on start up. | jimbobrand | Issues | Warranty | Recalls / TSB | 18 | 01-13-2014 11:34 AM |
| Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! | MotivConcepts | Engine, Exhaust, Bolt-Ons | 96 | 07-19-2013 02:03 AM |
