Northern California NorCal
Old 03-22-2014, 10:49 PM   #1
Shaun Perry
Shaun Perry's Avatar
Overpipe knocking?
Is anyone else on the forum running the Agency Power Overpipe/Frontpipe slip in unit?
After installing, I started hearing and feeling "knocking". noticeable mostly when accelerating in 1st gear; either while turning from a dead stop(for example, making a U-turn) or accelerating hard from a dead stop.
Took the car to my local exhaust shop and saw that the overpipe itself was touching the cross-member shield that rides upward between the engine block and strut tower.
The technician loosened the flange between the over pipe and front pipe then temporarily, put a bar in there to separate the touching metal, gave it a few pushes to open up a gap, let the pipes cool down, bolted and tightened everything back and then removed the bar.
It made a noticeable gap of space and the OP was now free of touching anything. It helped for about a day or so but now I'm hearing the knocking again.
Running OEM Headers and OEM midpipe still btw.
Sorry for the novel, trying to be as detailed as possible.
Any ideas or help/advice would be appreciated.
Thanks in advance.
SBD Turbo V2 | OFT Flexfuel Kit; Tuned by Shiv @10psi | Nameless 2.5in. 1-piece OP/FP | Full Custom Center Exit/SS dual tip cat-back exhaust | KateCOOL Oil Cooler | Mishimoto T-Stat sandwhich plate | ACT XT Street Clutch Kit; 10.5lb flywheel | RSR Black-i Coilovers | Rota Torque 17x9 +30 | Bayson R front lip/side skirts/rear spats and rear windshield visor
Shaun Perry is offline   Reply With Quote
Old 03-22-2014, 11:06 PM   #2
s2d4
s2d4's Avatar
Replace it with a better quality piece.
The Following User Says Thank You to s2d4 For This Useful Post:
kiichiro (03-26-2014)
Old 03-22-2014, 11:15 PM   #3
Shaun Perry
Awesome input lol very helpful
Old 03-22-2014, 11:27 PM   #4
s2d4
s2d4's Avatar
What kind of input would you like?
Eliminate the problem or mask the problem?
Old 03-22-2014, 11:31 PM   #5
Shaun Perry
I was more looking for someone to chime in who has or has had a similar issue. Unless you would like to purchase me new parts, I like to see if I can take it upon myself to fix the issue first before giving up
Old 03-22-2014, 11:33 PM   #6
s2d4
s2d4's Avatar
The issue is bad quality product.
Wrap it may help but it isn't fixing the issue.
Can't you return it citing bad figment?
Old 03-22-2014, 11:35 PM   #7
Shaun Perry
Not entirely, I took it off a friend used. Who had no issues with it while on his car, although he was running an aftermarket header. Maybe that is what's needed, which sucks to know even though they claim the part works with oem headers.
Old 03-25-2014, 02:59 PM   #8
whathedunk
Drives: LR BRZ
I have UEL headers for sale
whathedunk is offline   Reply With Quote
Old 03-25-2014, 03:17 PM   #9
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Joking aside, maybe the problem is in the fitment. I'm having trouble picturing it, but I would try to loosen up all the other pieces and see if you can adjust any of them to get any extra room, although I'm positive your exhaust shop would have tried that already.
Old 03-25-2014, 07:35 PM   #10
chutrain
chutrain's Avatar
Drives: WRB BRZ
Are you sure it is just hitting the cross member? I had mine hitting the swaybar.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 03-26-2014, 11:41 AM   #11
Shaun Perry
He did loosen up one section but I'm debating whether to go back and just have loosen everything else like you said and see if he can fix it like that.
Should have taken pictures when I was under there with the car on his lift lol.
Old 03-26-2014, 11:42 AM   #12
Shaun Perry
It's just an assumption from witness marks on the over pipe and cross member.
How did you know it was hitting your sway?
And just to clarify you were also running oem headers + agency power over pipe & front pipe?
Old 03-26-2014, 11:43 AM   #13
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
What are you selling bro?!
OP- That sounds weird, did you have your friend check it out since he didn't have any issues with his?
Kelbyat07 is offline   Reply With Quote
Old 03-26-2014, 01:07 PM   #14
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Motor mounts
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Knocking sound Moe23 Issues | Warranty | Recalls / TSB 80 04-18-2019 08:09 PM
Knocking doesn't sound good :-(. TheMarkness Issues | Warranty | Recalls / TSB 41 02-04-2015 10:38 PM
Knocking on Startup? 636 Issues | Warranty | Recalls / TSB 17 02-03-2014 07:18 AM
Knocking/Rattle on start up. jimbobrand Issues | Warranty | Recalls / TSB 18 01-13-2014 11:34 AM
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
