Old 11-12-2013, 11:46 AM   #1
jimbobrand
jimbobrand's Avatar
Drives: 2013 Subaru BRZ Premium
Knocking/Rattle on start up.
Hey guys, I had a weird issue this morning when I started up my BRZ. Upon start up it made a knocking noise that sounded a bit like detonation but went away after a second or two. This was followed by a small ammount of knocking/rattling (quiet and only lasting 1-2 seconds) while driving down the street and then nothing after that. I've had my car since June 2012 and I have 32,000+ miles on it and this is the first time this has happened. I've had no CELs and my only mods are a Nameless axelback and a AFE intake that have been on the car for a year. Anyone else have this issue or had something similar happen? Thanks!
Jim Brand
2013 Subaru BRZ Premium 6MT WRBP
Oklahoma Subaru Crew-OKSC.org
TXIC San Antonio
jimbobrand is offline   Reply With Quote
Old 11-13-2013, 01:50 PM   #2
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Just noticed this morning as well. Maybe its the colder weather. It was only knocking during idle in traffic. It went away after 2 miles.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 11-13-2013, 08:11 PM   #3
Mikem53
Drives: FR-S 6MT
same here.. This morning was the coldest I experienced with this car.
it was garaged and probably upper 50's in there when I fired it up..
It popped and ran rough for a second or two.. ran fine after it warmed up..
Had 2 hours worth of driving later and it runs fine.. First time in 4500 miles
that I heard it pop and studder.. not concerned about it.. but this is one
weird little engine.
Mikem53 is offline   Reply With Quote
Old 11-13-2013, 08:12 PM   #4
ronboogieon
BReeZy Hunter
ronboogieon's Avatar
Drives: 13 DGM BRZ Limited 6MT
Mine did this morning too. I read in some other thread that its the cats warming up.
ronboogieon is offline   Reply With Quote
Old 11-13-2013, 08:32 PM   #5
Suberman
Drives: Subaru BRZ Sport Tech Satin White
If you fit a cold air intake you will experience problems in cold weather. If cold air intakes actually worked then manufacturers would install them. They don't work and they don't.
Suberman is offline   Reply With Quote
Old 11-13-2013, 08:49 PM   #6
mainstream
mainstream's Avatar
Same at 6pm tonight
46 degrees out had a rough idle for about 6-7 seconds then a kind of low pop that appears like it came from the back.
Went away after driving for 10-15 min
mainstream is offline   Reply With Quote
Old 11-14-2013, 11:33 AM   #7
jimbobrand
jimbobrand's Avatar
If that were the case then I should have experienced this last year since I installed the AFE intake in October 2012 and about 20,000 miles ago. The morning that this happened wasn't even the coldest morning this week and it hasn't happened since when it's been colder.
Jim Brand
TXIC San Antonio
Old 11-14-2013, 10:00 PM   #8
GarageBRZTuning
GarageBRZTuning's Avatar
Drives: 2013 Subaru BRZ Limited Silver MT
I recently installed a K&N Cold Air Intake in my BRZ and noticed the same problem on a cold start-up. My car only has 1300 miles and on it and I honestly thought it was the intake.. After taking the intake out and putting the OEM Intake in the problem didn't go away... If anything the noise actually got quieter. I'm taking it the the dealership in a couple of weeks and seeing if they know what's wrong with it! Glad to know I"m not the only one that experienced this problem. Thanks for letting me know I'm not going insane!!
GarageBRZTuning is offline   Reply With Quote
Old 11-14-2013, 10:11 PM   #9
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
This car has some crazy startup sounds in the cold, the exhaust is very loud for the first 10-15 seconds. And the engine itself is also very loud.
Rayme is offline   Reply With Quote
Old 11-14-2013, 10:58 PM   #10
BRZnut
Drives: BRZ DGM Limited
mine too..last winter and now this fall--->on cold days (below 50 degrees F), the engine starts very rough with an occl pop sound at idle. Once driving, everything is ok. The twins just hate the cold! (like my wife!)
Old 11-15-2013, 08:43 AM   #11
jimbobrand
jimbobrand's Avatar
My car will be going back to the dealership this afternoon for the cam plate/oil leak issue (again) and I'm going to have them look into the knocking on start-up. It hasn't made the noise since but I'm hoping that they could at least eliminate detonation from the list of possibilities.
Jim Brand
TXIC San Antonio
Old 11-16-2013, 04:57 PM   #12
airmanmurphy02
Petrol head
airmanmurphy02's Avatar
i'm guessing cold weather too. mine does it after sitting outside at work in the parking lot all day, but not in the morning in the garage. kinda bothered me the first time.. though after a couple blips of the throttle it goes away and doesn't return.
Sic Semper Tyrannis!
airmanmurphy02 is offline   Reply With Quote
Old 11-16-2013, 08:13 PM   #13
Razz
Razz's Avatar
Drives: Fast
Popping sound in the cold is probably from your DI seals shrinking.
Razz is offline   Reply With Quote
Old 01-10-2014, 04:55 PM   #14
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Any update with the knocking in the morning? What did the dealer say?
φφκα
Exhaust rattle on cold start? Laurie Scion FR-S / Toyota 86 GT86 General Forum 8 12-04-2020 07:15 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
Front KNocking Noie and Gear Lever rattle Naughty AFRICA 17 10-26-2013 02:56 PM
Exhaust vibration/rattle at cold start? Foobar Engine, Exhaust, Transmission 7 04-16-2013 05:15 PM
Knocking sounds from lowering springs? bbaik Issues | Warranty | Recalls / TSB 7 03-07-2013 11:50 PM
