Old 02-01-2014, 03:38 PM   #1
636
636's Avatar
Drives: '23 CWP BRZ
Knocking on Startup?
So I've noticed recently when starting my car in the colder temps, when it's cold, it will make a noticable "knock" sound when I first turn it on.
It goes away, and the car doesn't make any other knocking sounds besides that, only when it's cold and it's the first start.
Should I be worried?
636 is offline   Reply With Quote
Old 02-01-2014, 03:56 PM   #2
JB86'd
JB86'd's Avatar
Drives: JAWS
Try searching...or just scrolling down.
http://www.ft86club.com/forums/showthread.php?t=56131
Old 02-01-2014, 04:04 PM   #3
636
636's Avatar
Drives: '23 CWP BRZ
That's not what I'm experiencing. It's not when the car drops to idle, there's no problems there.
It's as it's clicking over, it sounds like it knocks hard right before it starts up.
Old 02-01-2014, 04:09 PM   #4
humfrz
I wouldn't be worried; the engine is a mechanical thing just getting limbered up......
Old 02-01-2014, 04:46 PM   #5
JB86'd
JB86'd's Avatar
Drives: JAWS
Ah, you said as you first turned it on so I assumed idle. My bad. In that case..I can't help you.
Old 02-01-2014, 05:07 PM   #6
BRZnut
Drives: BRZ DGM Limited
My BRZ does the same thing since day one when starting in cold weather, and I think others have report the same.
Old 02-02-2014, 01:18 AM   #7
Apex-Wolf
Apex-Wolf's Avatar
Drives: Ultramarine Scion FR-S
Does it sound like this guys video???
http://www.ft86club.com/forums/showthread.php?t=57240
Apex-Wolf is offline   Reply With Quote
Old 02-02-2014, 09:34 AM   #8
frs10
Drives: tezla
wow that sounds pretty bad...
the knocking from cold weather is pretty common for most cars...?
frs10 is offline   Reply With Quote
Old 02-02-2014, 12:30 PM   #9
636
636's Avatar
Drives: '23 CWP BRZ
Nope, mine only happens for a split second, then never heard again.
Old 02-02-2014, 12:34 PM   #10
BlackyRose
Drives: 2013 Raven FR-S
Im also in Florida, I get 1-2 hard shaking knocks when I start my car up every cold morning. Perfectly normal.
BlackyRose is offline   Reply With Quote
Old 02-02-2014, 01:13 PM   #11
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Are you sure it's not the pre cat warming up...?
Old 02-02-2014, 11:25 PM   #12
636
636's Avatar
Drives: '23 CWP BRZ
Nah, it's not that crazy. I'll try to capture a video next time I go out.
Old 02-03-2014, 01:01 AM   #13
Bach415
Bach415's Avatar
Drives: Whiteout FRS
@636 its something like a few knocks after you start up the car for the first time of the day then its gone the rest of the day/occurs once a while right? If so I get it once a few start up due to the car being parked outside in the cold. The rpm do drop due to the knock from what I've seen.
Bach415 is offline   Reply With Quote
Old 02-03-2014, 01:03 AM   #14
636
636's Avatar
Drives: '23 CWP BRZ
No. This is not after a startup at ALL, it's DURING. It's as if the motor shakes so violently during turning on that it's knocking into something.
Knocking sound Moe23 Issues | Warranty | Recalls / TSB 80 04-18-2019 08:09 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
Knocking/Rattle on start up. jimbobrand Issues | Warranty | Recalls / TSB 18 01-13-2014 11:34 AM
STD Standard Suspension R3 Coilovers knocking FutureFT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2013 12:49 PM
Knocking sounds from lowering springs? bbaik Issues | Warranty | Recalls / TSB 7 03-07-2013 11:50 PM
