Old 03-06-2014, 10:17 AM   #1
PollosHermanos
PollosHermanos's Avatar
Drives: 2014 SWP BRZ Limited 6SP
Window Regulator Bolts/Washers - TSB and new parts?
DOUBLE POST: Mods please delete my double post. Sorry about that!
I brought the BRZ (2800 miles - stock) in to my dealer this morning to have a clunking noise coming from my driver's side door addressed.
The issue was that when operating the window there were two distinct clunks when the window started to move and then another about halfway up. It would happen both going up and down.
They had it taken care of in about an hour and said that they did find that the bolts that attached the window motor regulator to the door had come lose and that was causing the noises as the regulator rattled against the bolts/what it was supposed to be secured to.
Anyhow they told me that there was a revision and now I have new bolts and also washers which were apparently not part of the original build. Washers! What a concept.
Is this a known TSB/part revision ? I searched but didn't come up with anything.
Irony department: when I got to work and parked I heard my first crickets. Of course.
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now.
Last edited by PollosHermanos; 03-06-2014 at 10:34 AM. Reason: DOUBLE POST: Mods please delete my double post. Sorry about that!
PollosHermanos is offline   Reply With Quote
Old 03-08-2014, 10:49 AM   #2
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
I have this same problem, all they did for me was adjust the regulator and call it good.
fixed it for about 2 door opens and now it sounds the same. i give up
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
Old 03-08-2014, 01:14 PM   #3
andrew20195
Drives: 2013 Subaru BRZ
I don't see a TSB on this issue unless they're talking about the frozen window TSB. Seems like a reasonable repair for that issue, however.
andrew20195 is offline   Reply With Quote
Old 03-08-2014, 01:17 PM   #4
PollosHermanos
Yea it seems to have worked great but then again I don't use the window a whole lot since its been so cold. I'm wondering if the passenger side will have the same fate.
We shall see...
Sent from my HTC One using Tapatalk
OEM parts? Burned rubber door/window sill l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 04-08-2017 07:32 PM
Guys/Gals who installed KWV3 install these washers? OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-14-2013 01:35 AM
Where can I buy the trans and diff washers? ngabdala Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 05-09-2013 12:35 AM
Can the transmission crush washers be reused? brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 04-15-2013 07:35 PM
MT fill and drain washers diirk Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 11-09-2012 12:24 AM
