Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Really weird problem: Have to fill with fuel very slowly
Past few weeks, the fill ups I have done have been very difficult. Every gas station I visit (I've tried multiple different stations, brands, etc), clicks off, as if the tank is full, as soon as I start pumping anywhere near full speed.
I originally attributed this to a few particular stations but then I returned to the station where I've been filling the car primarily for the past year and it does it too! If I pull the handle more than 40-50%, it clicks off as if I'm full. At one station, it caused an overfill when my tank was near bone dry, filled fuel all over the car! I'm getting around 2 gallons per minute, if I'm good enough to never pull too far. You can hear the fuel level getting high in the filler tube as if you're getting close to full, too. It's like my filler tube has shrunk. This has only been occurring over the past month. Car is nearly 2 years old, 29k on it. Has anyone else experienced this? Going to take it to the dealer for this soon, just not sure when.
Drives: 2012 Scion TC
It goes away and that's all I know, happened to me I thought it had something to do with air and pressure but Idk
Drives: Scion FR-S
Found this article that might help:
http://m.theglobeandmail.com/globe-d...service=mobile |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Check for kinked line
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
Drives: Grocery cart
Sounds like a possible EVAP system issue.
SOLD: 2014 BRZ Limited WRB 6 Speed.
#6 | |
Drive From Home
Drives: BRZ STI Performance
Dodging cones
That's not the issue here; it happened when I was running on fumes as well
Have you tried turning the gas nozzle a different direction? I've had a couple of cars that you had to hold the nozzle at like a 4 or 8 o'clock position in stead of the usual 6 o'clock position.
Drive From Home
The dealer told me there's a vent for the gas tank that can get clogged up with spiderwebs or other foreign objects that can cause this problem, and once they clear this vent (which is a neck that runs parallel to the fuel filler), this problem should go away. They said they have seen this even with new cars sitting on the lot.
#10 |
Drives: FR-S 10 #103 AT
Never experienced it with this car but my teenager's old PT Cruiser did it. It was brutal. You could barely get it to take gas at all. Turned out there is a filter in the evap system that gets screwed up if you "top off" the gas when you fill up, which his biological father taught him to do. Odd thing is that replacing the filter only worked for a while and it came back even though the kid swears he stopped topping the car off.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#11 | ||
Drives: 2013 Subaru BRZ
#12 |
Dodging cones
It sounds blocked. You can hear it getting 'full' right away when you start pumping, like thereis air filling too much space.
Going to the dealer tomorrow to service
#13 |
Drives: '13 GBS Subaru BRZ
This sounds like the evaporative emissions filter is clogged. When filling do you stop when it clicks off or do you pull the handle a few more times to top it off? Topping off like that can cause fuel to flood the filter and clog it.
#14 |
Drives: '14 BRZ
Some people have had issues with the inside of the fuel filler hose collapsing. The inner liner falls off of the outer so you can't see it till you take off the tube and look inside. Dealer should replace under warranty.
| Slowly losing (and smelling) coolant | PantsDants | Issues | Warranty | Recalls / TSB | 11 | 01-31-2016 09:52 PM |
| Here we go -- Slowly, but surely | MadFRS | Member's Car Journals | 16 | 02-24-2014 06:30 PM |
| Fuel Filler Neck Problem | afohlin | Issues | Warranty | Recalls / TSB | 7 | 01-01-2014 01:13 PM |
| Fuel Gauge problem | adan | CANADA | 2 | 09-24-2013 11:12 PM |
| AFR Problem (maybe Fuel Pump installation bad) | whitefrs | Engine, Exhaust, Transmission | 37 | 08-30-2013 02:36 PM |
